Zum Hauptinhalt wechseln
How to Apply New Outer Screen Adhesive in Your Google Pixel Fold
Was du brauchst
  1. How to Apply New Outer Screen Adhesive in Your Google Pixel Fold, Apply the top right adhesive: Schritt 1, Bild 1 von 3 How to Apply New Outer Screen Adhesive in Your Google Pixel Fold, Apply the top right adhesive: Schritt 1, Bild 2 von 3 How to Apply New Outer Screen Adhesive in Your Google Pixel Fold, Apply the top right adhesive: Schritt 1, Bild 3 von 3
    • If you're reusing the small top right adhesive, skip the steps including it.
    • Peel off the new small top right adhesive strip from its clear liner.
    • Place the new adhesive on the top right bracket of the frame.
    • Use a spudger, or your fingers, to press down the adhesive to adhere it.
  2. How to Apply New Outer Screen Adhesive in Your Google Pixel Fold, Align the adhesive: Schritt 2, Bild 1 von 3 How to Apply New Outer Screen Adhesive in Your Google Pixel Fold, Align the adhesive: Schritt 2, Bild 2 von 3 How to Apply New Outer Screen Adhesive in Your Google Pixel Fold, Align the adhesive: Schritt 2, Bild 3 von 3
    • Before removing any liners, check if the large perimeter adhesive matches the frame.
    • The clear liner should face the frame.
    • Look for cutouts in the liner to help orient the adhesive.
  3. How to Apply New Outer Screen Adhesive in Your Google Pixel Fold, Apply the adhesive: Schritt 3, Bild 1 von 3 How to Apply New Outer Screen Adhesive in Your Google Pixel Fold, Apply the adhesive: Schritt 3, Bild 2 von 3 How to Apply New Outer Screen Adhesive in Your Google Pixel Fold, Apply the adhesive: Schritt 3, Bild 3 von 3
    • Be careful during this step, as it's easy to stick the adhesive in the wrong spot. Take your time and work slowly.
    • Peel off the new adhesive strip from its clear liner.
    • Align the adhesive over the frame, starting with the top left and bottom left edges.
    • Place the adhesive over the perimeter of the frame.
  4. How to Apply New Outer Screen Adhesive in Your Google Pixel Fold: Schritt 4, Bild 1 von 3 How to Apply New Outer Screen Adhesive in Your Google Pixel Fold: Schritt 4, Bild 2 von 3 How to Apply New Outer Screen Adhesive in Your Google Pixel Fold: Schritt 4, Bild 3 von 3
    • Use flat end of a spudger, or your fingers, to press down the adhesive and adhere it to the frame.
  5. How to Apply New Outer Screen Adhesive in Your Google Pixel Fold, Peel the large liner: Schritt 5, Bild 1 von 2 How to Apply New Outer Screen Adhesive in Your Google Pixel Fold, Peel the large liner: Schritt 5, Bild 2 von 2
    • Peel up the segmented tab at the bottom left corner of the large blue liner.
  6. How to Apply New Outer Screen Adhesive in Your Google Pixel Fold, Reconnect the back glass: Schritt 6, Bild 1 von 3 How to Apply New Outer Screen Adhesive in Your Google Pixel Fold, Reconnect the back glass: Schritt 6, Bild 2 von 3 How to Apply New Outer Screen Adhesive in Your Google Pixel Fold, Reconnect the back glass: Schritt 6, Bild 3 von 3
    • Lift the tab and peel off the large blue liner to expose the secondary liner.
  7. How to Apply New Outer Screen Adhesive in Your Google Pixel Fold, Reconnect the screen: Schritt 7, Bild 1 von 3 How to Apply New Outer Screen Adhesive in Your Google Pixel Fold, Reconnect the screen: Schritt 7, Bild 2 von 3 How to Apply New Outer Screen Adhesive in Your Google Pixel Fold, Reconnect the screen: Schritt 7, Bild 3 von 3
    • Support the screen with your hand or prop it up on something sturdy.
    • Reconnect the screen cable.
    • Reconnect the flip battery cable.
    • Use a Torx Plus 3IP driver to refasten the bottom bracket.
  8. How to Apply New Outer Screen Adhesive in Your Google Pixel Fold, Peel the secondary liner: Schritt 8, Bild 1 von 2 How to Apply New Outer Screen Adhesive in Your Google Pixel Fold, Peel the secondary liner: Schritt 8, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Use tweezers, or your fingers, to peel up either one of the tabs at the top right corner of the secondary liner.
    • If the adhesive starts separating, use a spudger to hold it down while peeling.
  9. How to Apply New Outer Screen Adhesive in Your Google Pixel Fold, Apply the back glass: Schritt 9, Bild 1 von 3 How to Apply New Outer Screen Adhesive in Your Google Pixel Fold, Apply the back glass: Schritt 9, Bild 2 von 3 How to Apply New Outer Screen Adhesive in Your Google Pixel Fold, Apply the back glass: Schritt 9, Bild 3 von 3
    • Lift the tab and peel off the secondary liner to expose the top adhesive.
  10. How to Apply New Outer Screen Adhesive in Your Google Pixel Fold, Expose the top right adhesive: Schritt 10, Bild 1 von 2 How to Apply New Outer Screen Adhesive in Your Google Pixel Fold, Expose the top right adhesive: Schritt 10, Bild 2 von 2
    • Remove the blue liner from the top right adhesive strip.
  11. How to Apply New Outer Screen Adhesive in Your Google Pixel Fold, Apply the screen: Schritt 11, Bild 1 von 2 How to Apply New Outer Screen Adhesive in Your Google Pixel Fold, Apply the screen: Schritt 11, Bild 2 von 2
    • Align the screen over its cutout in the frame.
    • Place a right edge of the screen on the frame, making sure there are no gaps or jutting adhesive.
    • Place the left edge of the screen on the frame.
  12. How to Apply New Outer Screen Adhesive in Your Google Pixel Fold: Schritt 12, Bild 1 von 3 How to Apply New Outer Screen Adhesive in Your Google Pixel Fold: Schritt 12, Bild 2 von 3 How to Apply New Outer Screen Adhesive in Your Google Pixel Fold: Schritt 12, Bild 3 von 3
    • Press down along the perimeter of the screen to adhere it to the frame.
    • Let the phone sit a few hours for the adhesive to cure.
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel Fold Answers Community for help.
2 weitere Personen haben diese Anleitung absolviert.
Alex Diaz-Kokaisl
199.526 Reputation
942 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
122 Mitglieder
23.342 Anleitungen geschrieben
4 Kommentare zur Anleitung
Thanks for the write-up!
It was a simple enough process, but having clear and consise step-by-step instructions like this really takes most of the intimidation factor out of DIY repairs for many.
Cheers man,
Lots of appreciation from VA.
velocity211 - Antwort
Is the center screen above just the touch screen for $800.000
If not where can I buy one? No LCD NEEDED. Just inner screen
Annacando - Antwort
Can you buy just the adhesive sheets shown in the replacement steps?
Victor V - Antwort
I can’t imagine google sells the adhesive for the screen. A big well known online retailer sells rolls of 2mm double sided tape for phones specifically. They look like thin red rolls. You’d just have to cut it yourself to fit the frame.
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 18
Letzte 30 Tage: 47
Insgesamt: 634
