Zum Hauptinhalt wechseln
How to Clean Corroded Battery Terminals
Was du brauchst
  1. How to Clean Corroded Battery Terminals, Safety precautions: Schritt 1, Bild 1 von 1
    • Wear gloves to protect your hands from the corrosion—it's a skin irritant.
    • If your device still works, power it down completely before starting.
  2. How to Clean Corroded Battery Terminals, Remove the batteries: Schritt 2, Bild 1 von 3 How to Clean Corroded Battery Terminals, Remove the batteries: Schritt 2, Bild 2 von 3 How to Clean Corroded Battery Terminals, Remove the batteries: Schritt 2, Bild 3 von 3
  3. How to Clean Corroded Battery Terminals, Remove big chunks of corrosion: Schritt 3, Bild 1 von 3 How to Clean Corroded Battery Terminals, Remove big chunks of corrosion: Schritt 3, Bild 2 von 3 How to Clean Corroded Battery Terminals, Remove big chunks of corrosion: Schritt 3, Bild 3 von 3
    • Use a toothbrush to gently remove any bigger chunks of corrosion from the battery terminals and battery recess.
    • Use the point of a spudger to pick out any bits that are stuck.
    • Pick around the batteries, and not at the batteries themselves.
    • Flip your device over and gently shake out the loose corrosion and debris.
    • Dispose of the corrosion and debris in the trash.
  4. How to Clean Corroded Battery Terminals, Remove any stuck batteries: Schritt 4, Bild 1 von 2 How to Clean Corroded Battery Terminals, Remove any stuck batteries: Schritt 4, Bild 2 von 2
    • You should now be able to remove any batteries that were previously stuck.
    • Clean out the battery recess with a toothbrush.
  5. How to Clean Corroded Battery Terminals, Clean the terminals: Schritt 5, Bild 1 von 3 How to Clean Corroded Battery Terminals, Clean the terminals: Schritt 5, Bild 2 von 3 How to Clean Corroded Battery Terminals, Clean the terminals: Schritt 5, Bild 3 von 3
    • Alkaline batteries contain a base, which is what corrosion is made of. An acid like white vinegar or lemon juice will neutralize this base.
    • Lightly dip a cotton swab in white vinegar or lemon juice.
    • Don't soak the cotton swab. Only use a small amount of liquid at a time.
    • Gently rub the battery terminals with the cotton swab to dissolve and remove the corrosion.
    • The corrosion may fizz and bubble. Don't worry, this is normal.
    • Continue this process until there's no corrosion on the terminals.
  6. How to Clean Corroded Battery Terminals: Schritt 6, Bild 1 von 3 How to Clean Corroded Battery Terminals: Schritt 6, Bild 2 von 3 How to Clean Corroded Battery Terminals: Schritt 6, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Microfiber Cleaning Cloths
    $3.99
    Kaufen
    • Isopropyl alcohol will remove any residue left from the previous step.
    • Lightly dip a cotton swab in highly-concentrated isopropyl alcohol (over 90%).
    • Gently rub the battery terminals with the cotton swap to remove any remaining residue from the previous step.
    • Wipe the residue away with a microfiber or lint-free cloth.
    • Repeat this process until the terminals are completely clean.
    • Wait two minutes to allow any residual alcohol to evaporate.
  7. How to Clean Corroded Battery Terminals, Install new batteries: Schritt 7, Bild 1 von 3 How to Clean Corroded Battery Terminals, Install new batteries: Schritt 7, Bild 2 von 3 How to Clean Corroded Battery Terminals, Install new batteries: Schritt 7, Bild 3 von 3
Abschluss
Cleaning didn’t go as planned? Ask our Answers community for help.
For other electronics skills, click here.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Spencer Day
55.149 Reputation
408 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
136 Mitglieder
17.410 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 34
Letzte 7 Tage: 230
Letzte 30 Tage: 1,187
Insgesamt: 5,238
