Zum Hauptinhalt wechseln
How to Install a New Battery in Your Samsung Galaxy S22 or S22+
Was du brauchst
  1. How to Install a New Battery in Your Samsung Galaxy S22 or S22+, Clean the frame: Schritt 1, Bild 1 von 2 How to Install a New Battery in Your Samsung Galaxy S22 or S22+, Clean the frame: Schritt 1, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use your fingers or tweezers to peel up and remove any large pieces of adhesive from the frame.
    • Apply a few drops of highly-concentrated isopropyl alcohol (greater than 90%) to the remaining adhesive.
    • Use the flat end of a spudger to scrape off all remaining adhesive.
  2. How to Install a New Battery in Your Samsung Galaxy S22 or S22+: Schritt 2, Bild 1 von 1
    Microfiber Cleaning Cloths
    $3.99
    Kaufen
    • Apply a few more drops of highly-concentrated isopropyl alcohol (greater than 90%) to any adhesive residue on the frame and wipe it away with a microfiber or lint-free cloth.
  3. How to Install a New Battery in Your Samsung Galaxy S22 or S22+, Measure and cut the tape: Schritt 3, Bild 1 von 3 How to Install a New Battery in Your Samsung Galaxy S22 or S22+, Measure and cut the tape: Schritt 3, Bild 2 von 3 How to Install a New Battery in Your Samsung Galaxy S22 or S22+, Measure and cut the tape: Schritt 3, Bild 3 von 3
    Tesa 61395 Tape
    $2.99
    Kaufen
  4. How to Install a New Battery in Your Samsung Galaxy S22 or S22+, Apply the strips of tape: Schritt 4, Bild 1 von 3 How to Install a New Battery in Your Samsung Galaxy S22 or S22+, Apply the strips of tape: Schritt 4, Bild 2 von 3 How to Install a New Battery in Your Samsung Galaxy S22 or S22+, Apply the strips of tape: Schritt 4, Bild 3 von 3
    • Lay a strip of tape onto the frame.
    • Use the flat end of your spudger to press down firmly along the whole strip to secure it.
    • Use tweezers to remove the liner from the strip of tape.
  5. How to Install a New Battery in Your Samsung Galaxy S22 or S22+: Schritt 5, Bild 1 von 3 How to Install a New Battery in Your Samsung Galaxy S22 or S22+: Schritt 5, Bild 2 von 3 How to Install a New Battery in Your Samsung Galaxy S22 or S22+: Schritt 5, Bild 3 von 3
    • Repeat the previous step to apply the remaining strips of tape.
  6. How to Install a New Battery in Your Samsung Galaxy S22 or S22+, Secure the battery: Schritt 6, Bild 1 von 3 How to Install a New Battery in Your Samsung Galaxy S22 or S22+, Secure the battery: Schritt 6, Bild 2 von 3 How to Install a New Battery in Your Samsung Galaxy S22 or S22+, Secure the battery: Schritt 6, Bild 3 von 3
    • While holding the battery above its recess, reconnect the battery cable.
    • This ensures the battery is properly aligned.
    • Lay the battery into its recess in the frame.
    • Press down firmly on the entire surface of the battery to secure it with the tape.
    • Disconnect the battery.
    • Return to your repair guide and continue reassembly.
    • S22
    • S22+
Abschluss
For optimal performance, calibrate your newly installed battery after completing your repair.
Spencer Day
55.203 Reputation
408 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
136 Mitglieder
17.430 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 66
Letzte 30 Tage: 180
Insgesamt: 1,235
