Zum Hauptinhalt wechseln
How to Open the Logitech MX Ergo
Was du brauchst
  1. How to Open the Logitech MX Ergo, Power off the mouse: Schritt 1, Bild 1 von 3 How to Open the Logitech MX Ergo, Power off the mouse: Schritt 1, Bild 2 von 3 How to Open the Logitech MX Ergo, Power off the mouse: Schritt 1, Bild 3 von 3
    • Before you begin, flip the mouse's power switch into the OFF position.
  2. How to Open the Logitech MX Ergo, Remove the cover: Schritt 2, Bild 1 von 2 How to Open the Logitech MX Ergo, Remove the cover: Schritt 2, Bild 2 von 2
    • Remove the magnetic cover by pulling it away from the bottom mouse half.
  3. How to Open the Logitech MX Ergo, Remove the case screws: Schritt 3, Bild 1 von 1
    • Use a Torx T6 screwdriver to remove the six 5.7 mm-long screws securing the two halves of the mouse together.
  4. How to Open the Logitech MX Ergo, Remove the trackball: Schritt 4, Bild 1 von 3 How to Open the Logitech MX Ergo, Remove the trackball: Schritt 4, Bild 2 von 3 How to Open the Logitech MX Ergo, Remove the trackball: Schritt 4, Bild 3 von 3
    • Insert a spudger into the hole on the bottom of the mouse, located under the trackball.
    • Use the spudger to push the trackball out of its recess.
    • Remove the trackball.
  5. How to Open the Logitech MX Ergo, Unhinge the plastic clips: Schritt 5, Bild 1 von 3 How to Open the Logitech MX Ergo, Unhinge the plastic clips: Schritt 5, Bild 2 von 3 How to Open the Logitech MX Ergo, Unhinge the plastic clips: Schritt 5, Bild 3 von 3
    • There are clips all around the perimeter of the mouse case holding the two halves together.
    • Insert an opening pick into the gap on the right side of the mouse.
    • Rotate the opening pick about 30 degrees to unhinge the plastic clip.
  6. How to Open the Logitech MX Ergo: Schritt 6, Bild 1 von 2 How to Open the Logitech MX Ergo: Schritt 6, Bild 2 von 2
    • Slide the opening pick to the lower right side of the mouse.
  7. How to Open the Logitech MX Ergo: Schritt 7, Bild 1 von 2 How to Open the Logitech MX Ergo: Schritt 7, Bild 2 von 2
    • Slide the opening pick to the bottom side of the mouse.
    • Rotate the opening pick about 30 degrees to unhinge the plastic clip on the bottom end of the mouse.
  8. How to Open the Logitech MX Ergo: Schritt 8, Bild 1 von 2 How to Open the Logitech MX Ergo: Schritt 8, Bild 2 von 2
    • Slide the opening pick to the center of the left side next to the recess of the trackball.
    • Rotate the opening pick to unhinge the remaining plastic clip.
  9. How to Open the Logitech MX Ergo, Create access: Schritt 9, Bild 1 von 3 How to Open the Logitech MX Ergo, Create access: Schritt 9, Bild 2 von 3 How to Open the Logitech MX Ergo, Create access: Schritt 9, Bild 3 von 3
    • Don't completely separate the two halves yet—they're still tethered together by a delicate cable.
    • For better access, place the top half of the mouse to the left of the lower half of the mouse.
  10. How to Open the Logitech MX Ergo, Disconnect the interconnect cable: Schritt 10, Bild 1 von 2 How to Open the Logitech MX Ergo, Disconnect the interconnect cable: Schritt 10, Bild 2 von 2
    • Use the pointed end of a spudger to gently lift the left side of the black sliding lock on the interconnect cable socket until it stops.
  11. How to Open the Logitech MX Ergo: Schritt 11, Bild 1 von 2 How to Open the Logitech MX Ergo: Schritt 11, Bild 2 von 2
    • Use the pointed end of a spudger to gently lift the right side of the black sliding lock on the interconnect cable socket until it stops and the cable is no longer locked in.
  12. How to Open the Logitech MX Ergo, Remove the top half of the mouse: Schritt 12, Bild 1 von 3 How to Open the Logitech MX Ergo, Remove the top half of the mouse: Schritt 12, Bild 2 von 3 How to Open the Logitech MX Ergo, Remove the top half of the mouse: Schritt 12, Bild 3 von 3
    • Remove the top half of the mouse.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Adriana Zwink
48.265 Reputation
167 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
135 Mitglieder
16.817 Anleitungen geschrieben
3 Kommentare
Thank you. It was quite a coincidence that I found this because I had just purchased that fix it repair tool kit. It was pretty handy that I had it all right here in front of me. Thanks again you made it easy.
Marti Roy - Antwort
Hi @martilynn, thank you for sharing your experience! We're glad that the guide was useful for your repair.
Adriana Zwink -
Very helpful guide! Managed to figure out how to clear some gunk off an end users mouse. Much appreciated!
Skurtsson - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 42
Letzte 30 Tage: 222
Insgesamt: 5,544
