Einleitung
Use this guide to remove the back cover of the Samsung Galaxy Watch4 Classic.
Was du brauchst
Before starting repairs, take your watch off the charger and power it down.
Remove the watch band.
Use a Tri-point Y00 screwdriver to remove the four 4.0 mm-long screws securing the back cover.
Insert an opening tool into the seam between the back cover and the metal housing.
Twist the opening tool to create a gap.
Lay the watch face down.
Carefully swing open the back cover by folding it to the opposite site of the created gap.
Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
Ein Kommentar
back cover rubber gasket, where can you find this? or is T-8000 glue ok?
