Zum Hauptinhalt wechseln
Huawei P20 Pro Rear Glass Replacement
Was du brauchst
  1. Huawei P20 Pro Rear Glass Replacement, Rear Glass Replacement: Schritt 1, Bild 1 von 1
    • Switch off your phone.
    • Use an iOpener to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes. You might want to repeat this step several times during the back cover removal.
    • The adhesive of the Huawei P20 Pro is of moderate strength, however a hair dryer, heat gun, or hot plate may also be used if you aren't able to open the device with the iOpener. Be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
  2. Huawei P20 Pro Rear Glass Replacement: Schritt 2, Bild 1 von 3 Huawei P20 Pro Rear Glass Replacement: Schritt 2, Bild 2 von 3 Huawei P20 Pro Rear Glass Replacement: Schritt 2, Bild 3 von 3
    • If the phone's rear glass is cracked, a suction cup may not stick very well. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Press a suction cup onto the rear glass close to the bottom edge of the phone.
    • Lift the bottom edge with the suction cup, opening a slight gap between the rear glass and the frame.
    • Insert an opening pick in the gap and slide it to the bottom right corner. Leave it there to prevent the adhesive from resealing.
  3. Huawei P20 Pro Rear Glass Replacement: Schritt 3, Bild 1 von 2 Huawei P20 Pro Rear Glass Replacement: Schritt 3, Bild 2 von 2
    • Insert a second opening pick and slide it to the bottom left corner. Leave it there to prevent the adhesive from resealing.
  4. Huawei P20 Pro Rear Glass Replacement: Schritt 4, Bild 1 von 3 Huawei P20 Pro Rear Glass Replacement: Schritt 4, Bild 2 von 3 Huawei P20 Pro Rear Glass Replacement: Schritt 4, Bild 3 von 3
    • Insert a third opening pick at the bottom left corner.
    • Slide the tip of the opening pick along the left edge of the phone to cut the adhesive.
    • Leave the opening pick in the top left corner of the phone to prevent the adhesive from resealing.
  5. Huawei P20 Pro Rear Glass Replacement: Schritt 5, Bild 1 von 2 Huawei P20 Pro Rear Glass Replacement: Schritt 5, Bild 2 von 2
    • In case you're having trouble to cut the adhesive, reapply the iOpener for another minute to loosen it.
    • Insert a fourth opening pick at the top left corner of the phone.
    • Slide the opening pick along the upper edge of the phone to cut the adhesive beneath the rear glass and leave it in the top right corner.
  6. Huawei P20 Pro Rear Glass Replacement: Schritt 6, Bild 1 von 3 Huawei P20 Pro Rear Glass Replacement: Schritt 6, Bild 2 von 3 Huawei P20 Pro Rear Glass Replacement: Schritt 6, Bild 3 von 3
    • Insert a fifth opening pick at the top right corner of the rear glass.
    • Slide the opening pick along the right edge of the phone to cut the remaining adhesive.
    • Don't open the phone all the way yet. The proximity sensor flex cable is still connected to the motherboard.
  7. Huawei P20 Pro Rear Glass Replacement: Schritt 7, Bild 1 von 3 Huawei P20 Pro Rear Glass Replacement: Schritt 7, Bild 2 von 3 Huawei P20 Pro Rear Glass Replacement: Schritt 7, Bild 3 von 3
    • Carefully lift the rear glass until you can reach the connector of the proximity sensor flex cable next to the rear camera assembly.
  8. Huawei P20 Pro Rear Glass Replacement: Schritt 8, Bild 1 von 2 Huawei P20 Pro Rear Glass Replacement: Schritt 8, Bild 2 von 2
    • Use the flat end of a spudger to pry up and disconnect the proximity sensor flex cable.
  9. Huawei P20 Pro Rear Glass Replacement: Schritt 9, Bild 1 von 2 Huawei P20 Pro Rear Glass Replacement: Schritt 9, Bild 2 von 2
    • Remove the rear glass.
    • Before installing fresh adhesive and reassembly, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
Abschluss
After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
18 weitere Nutzer:innen haben diese Anleitung absolviert.
Dominik Schnabelrauch
203.353 Reputation
682 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
135 Mitglieder
16.817 Anleitungen geschrieben
7 Kommentare
Do you suggest any particular kind of adhesive? I always have trouble with these things. Sooner or later, if not immediately, any glass or screen I fit this way always lifts up. The adhesives that come with the parts always seem weak. I try B-7000 glue or/and double sided tape, but still it won’t sit tight.
Smeargle - Antwort
Hi Smeargle, the options you already tried are also the ones I’d recommend. When applying new double-sided adhesive I’d also suggest slightly heating the glued area and applying some pressure for a few hours (stack of heavy books overnight might do).
Tobias Isakeit -
Hey how do you get the huawei sealed back?
For it to be waterproof again.
Léo Zakri - Antwort
You either buy a rear glass with seal attached or buy a seal and do it yourself, not sure why the author didn't go over this…
jasro -
Although I understand the steps, why did you not include steps to install the fresh rear glass?
jasro - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 44
Letzte 30 Tage: 160
Insgesamt: 38,511
