Einleitung
This guide shows you how to replace the broken display in your Huawei P8 Lite.
Was du brauchst
Use an Opening Tool and start to lever up the back cover of your Huawei P8 Lite at the bottom of your phone.
There are clips around the whole mid frame, holding down the back cover. Open all of them with the Opening Tool.
When all clips are open, remove the back cover from the rest of the phone.
Use a tweezer to remove the warranty sticker which sits on a screw in the bottom right of your phone.
Remove the 4 black Torx T5 screws which hold down the lower part of the loudspeaker.
Remove the three silver Phillips #00 screws which hold down the upper part of the loudspeaker.
Remove the three Phillips #00 screws that hold the metal plate in place.
Remove the metal plate with a tweezer.
Unplug the battery flex connector with a spudger.
Carefully pry off the plastic cover on the left side. The NFC antenna contacts might be slightly glued to the cover.
Then remove the top cover.
Remove the SIM card and SD card trays.
Disconnect the three plug connectors and one ZIF connector.
Remove the volume and power button cable.
Take out the motherboard by lifting the bottom part first.
Heat up the top, bottom and both sides of the display with an iOpener to soften the adhesive.
Use an opening pick to get underneath the top right part of the display and loosen the adhesive.
Only with the very tip of the opening pick slide along the side of the display towards the bottom.
Loosen the adhesive underneath the complete lower part of the display.
Slowly but constantly lift the bottom part of the display to get underneath the screen and further loosen the adhesive.
Thread the cable through the midframe.
Open the display all the way and remove it from the midframe.
To reassemble your device, follow these instructions in reverse order. Make sure to test the new display and remove any old residue from the adhesive.
31 weitere Personen haben diese Anleitung absolviert.
