Zum Hauptinhalt wechseln
IdeaPad L340-15API Battery Replacement
Was du brauchst
  1. IdeaPad L340-15API Battery Replacement, Optical Drive: Schritt 1, Bild 1 von 2 IdeaPad L340-15API Battery Replacement, Optical Drive: Schritt 1, Bild 2 von 2
    • Before beginning the repair, make sure that the device is fully powered off.
    • Turn the laptop over so the bottom cover is facing up.
    • The small screw hole near the center of the case, marked with a tiny DVD icon and an arrow, secures the optical drive.
    Frag FixBot
    Kommentar hinzufügen
  2. IdeaPad L340-15API Battery Replacement: Schritt 2, Bild 1 von 2 IdeaPad L340-15API Battery Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove the 7.5 mm screw securing the optical drive.
    • Place the screw down safely in a container/magnet strip where it will not get lost while you are working. These screws are very small and easily misplaced.
    Frag FixBot
  3. IdeaPad L340-15API Battery Replacement: Schritt 3, Bild 1 von 2 IdeaPad L340-15API Battery Replacement: Schritt 3, Bild 2 von 2
    • Place your thumb at the seam between the optical drive and the device.
    • Gently pull the component straight out from the device, taking care not to pull at an angle.
    Frag FixBot
  4. IdeaPad L340-15API Battery Replacement, Battery: Schritt 4, Bild 1 von 2 IdeaPad L340-15API Battery Replacement, Battery: Schritt 4, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove the twelve 7.5 mm screws from the back cover.
    Frag FixBot
  5. IdeaPad L340-15API Battery Replacement: Schritt 5, Bild 1 von 3 IdeaPad L340-15API Battery Replacement: Schritt 5, Bild 2 von 3 IdeaPad L340-15API Battery Replacement: Schritt 5, Bild 3 von 3
    • Insert a plastic opening pick in the back left corner and wedge the panel open.
    • Slide the pick around the edge of the laptop to release the clips as you lift the panel.
    • If the opening pick isn’t working, use the iFixit opening tool to gain more leverage.
    • Remove the bottom cover.
    Frag FixBot
  6. IdeaPad L340-15API Battery Replacement: Schritt 6, Bild 1 von 2 IdeaPad L340-15API Battery Replacement: Schritt 6, Bild 2 von 2
    • Use the Phillips #1 screwdriver to remove the five 6.5 mm screws securing the battery.
    • Use a container/magnet strip to store the screws while working.
    Frag FixBot
  7. IdeaPad L340-15API Battery Replacement: Schritt 7, Bild 1 von 3 IdeaPad L340-15API Battery Replacement: Schritt 7, Bild 2 von 3 IdeaPad L340-15API Battery Replacement: Schritt 7, Bild 3 von 3
    • Use the wide end of a spudger to push the connector tab, sliding the battery connector out of its socket.
    • It may take a lot of force to disconnect the cable. Go slowly, and don't pull on the cables.
    Frag FixBot
  8. IdeaPad L340-15API Battery Replacement: Schritt 8, Bild 1 von 1
    • Remove the battery from the laptop.
    Frag FixBot
Abschluss
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
For optimal performance, calibrate your newly installed battery after completing this guide.
Ian
347 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 2-5, Bowman Fall 2025 Mitglied von UMass Dartmouth, Team 2-5, Bowman Fall 2025
UMASSD-BOWMAN-F25S2G5
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 57
Insgesamt: 373
