Zum Hauptinhalt wechseln
LG Front Load Washing Machine Control Panel Replacement
Was du brauchst
    1. LG Front Load Washing Machine Control Panel Replacement, Safety Precautions: Schritt 1, Bild 1 von 2 LG Front Load Washing Machine Control Panel Replacement, Safety Precautions: Schritt 1, Bild 2 von 2
      • Before you begin your repair, perform the following:
      • Turn off the main water supply
      • Unplug your washer
      • Disconnect all water connections at the rear of your washer
      Frag FixBot
      Kommentar hinzufügen
    1. LG Front Load Washing Machine Control Panel Replacement, Unfasten the top panel: Schritt 2, Bild 1 von 3 LG Front Load Washing Machine Control Panel Replacement, Unfasten the top panel: Schritt 2, Bild 2 von 3 LG Front Load Washing Machine Control Panel Replacement, Unfasten the top panel: Schritt 2, Bild 3 von 3
      • Remove the screw(s) securing the top panel brackets to the back panel.
      • You don't need to remove the screws securing the brackets to the top panel.
      Frag FixBot
    2. LG Front Load Washing Machine Control Panel Replacement, Remove the top panel: Schritt 3, Bild 1 von 2 LG Front Load Washing Machine Control Panel Replacement, Remove the top panel: Schritt 3, Bild 2 von 2
      • Slide the top panel towards the rear of the device to disconnect its clips.
      Frag FixBot
    3. LG Front Load Washing Machine Control Panel Replacement: Schritt 4, Bild 1 von 2 LG Front Load Washing Machine Control Panel Replacement: Schritt 4, Bild 2 von 2
      • Tilt the top panel upward to completely disconnect it from the chassis.
      • Remove the top panel.
      Frag FixBot
    1. LG Front Load Washing Machine Control Panel Replacement, Remove the detergent drawer: Schritt 5, Bild 1 von 2 LG Front Load Washing Machine Control Panel Replacement, Remove the detergent drawer: Schritt 5, Bild 2 von 2
      • Pull the detergent drawer away from the chassis as far as it will go.
      Frag FixBot
    2. LG Front Load Washing Machine Control Panel Replacement: Schritt 6, Bild 1 von 3 LG Front Load Washing Machine Control Panel Replacement: Schritt 6, Bild 2 von 3 LG Front Load Washing Machine Control Panel Replacement: Schritt 6, Bild 3 von 3
      • Press down on the "Push" button to disengage the clips securing the detergent drawer.
      • Pull the drawer out of its slot on the chassis and remove it.
      Frag FixBot
    1. LG Front Load Washing Machine Control Panel Replacement, Disconnect the control panel: Schritt 7, Bild 1 von 3 LG Front Load Washing Machine Control Panel Replacement, Disconnect the control panel: Schritt 7, Bild 2 von 3 LG Front Load Washing Machine Control Panel Replacement, Disconnect the control panel: Schritt 7, Bild 3 von 3
      • Disconnect the connectors attached to the control panel.
      • Always grip cables by their connectors and not the wires themselves.
      Frag FixBot
    2. LG Front Load Washing Machine Control Panel Replacement, Unfasten the control panel: Schritt 8, Bild 1 von 2 LG Front Load Washing Machine Control Panel Replacement, Unfasten the control panel: Schritt 8, Bild 2 von 2
      • Remove the screw(s) securing the control panel.
      Frag FixBot
    3. LG Front Load Washing Machine Control Panel Replacement, Unfasten the detergent dispenser: Schritt 9, Bild 1 von 1
      • Remove the screw(s) securing the detergent dispenser.
      Frag FixBot
    4. LG Front Load Washing Machine Control Panel Replacement, Unclip the control panel: Schritt 10, Bild 1 von 3 LG Front Load Washing Machine Control Panel Replacement, Unclip the control panel: Schritt 10, Bild 2 von 3 LG Front Load Washing Machine Control Panel Replacement, Unclip the control panel: Schritt 10, Bild 3 von 3
      • Use a flathead screwdriver, or a pry tool, to unclip the control panel from the chassis.
      Frag FixBot
    5. LG Front Load Washing Machine Control Panel Replacement, Remove the control panel: Schritt 11, Bild 1 von 3 LG Front Load Washing Machine Control Panel Replacement, Remove the control panel: Schritt 11, Bild 2 von 3 LG Front Load Washing Machine Control Panel Replacement, Remove the control panel: Schritt 11, Bild 3 von 3
      • Remove the control panel, making sure to thread any cables through the chassis.
      Frag FixBot
    6. LG Front Load Washing Machine Control Panel Replacement, Unfasten the control panel board: Schritt 12, Bild 1 von 1
      • Flip the control panel over.
      • Remove the screw(s) securing the control panel board.
      Frag FixBot
    7. LG Front Load Washing Machine Control Panel Replacement, Remove the control panel board: Schritt 13, Bild 1 von 3 LG Front Load Washing Machine Control Panel Replacement, Remove the control panel board: Schritt 13, Bild 2 von 3 LG Front Load Washing Machine Control Panel Replacement, Remove the control panel board: Schritt 13, Bild 3 von 3
      • Pull the control panel board out of its slot and remove it.
      Frag FixBot
Abschluss
Repair didn’t go as planned? Ask our Answers community for help.
4 weitere Personen haben diese Anleitung absolviert.
Bill Gilbert
40.207 Reputation
261 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
123 Mitglieder
68.890 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 60
Letzte 30 Tage: 291
Insgesamt: 5,727
