Zum Hauptinhalt wechseln
LG Front Load Washing Machine Dampers Replacement
Was du brauchst
    1. LG Front Load Washing Machine Dampers Replacement, Safety Precautions: Schritt 1, Bild 1 von 2 LG Front Load Washing Machine Dampers Replacement, Safety Precautions: Schritt 1, Bild 2 von 2
      • Before you begin your repair, perform the following:
      • Turn off the main water supply
      • Unplug your washer
      • Disconnect all water connections at the rear of your washer
      Frag FixBot
      Kommentar hinzufügen
    1. LG Front Load Washing Machine Dampers Replacement, Unfasten the top panel: Schritt 2, Bild 1 von 3 LG Front Load Washing Machine Dampers Replacement, Unfasten the top panel: Schritt 2, Bild 2 von 3 LG Front Load Washing Machine Dampers Replacement, Unfasten the top panel: Schritt 2, Bild 3 von 3
      • Remove the screw(s) securing the top panel brackets to the back panel.
      • You don't need to remove the screws securing the brackets to the top panel.
      Frag FixBot
    2. LG Front Load Washing Machine Dampers Replacement, Remove the top panel: Schritt 3, Bild 1 von 2 LG Front Load Washing Machine Dampers Replacement, Remove the top panel: Schritt 3, Bild 2 von 2
      • Slide the top panel towards the rear of the device to disconnect its clips.
      Frag FixBot
    3. LG Front Load Washing Machine Dampers Replacement: Schritt 4, Bild 1 von 2 LG Front Load Washing Machine Dampers Replacement: Schritt 4, Bild 2 von 2
      • Tilt the top panel upward to completely disconnect it from the chassis.
      • Remove the top panel.
      Frag FixBot
    1. LG Front Load Washing Machine Dampers Replacement, Remove the detergent drawer: Schritt 5, Bild 1 von 2 LG Front Load Washing Machine Dampers Replacement, Remove the detergent drawer: Schritt 5, Bild 2 von 2
      • Pull the detergent drawer away from the chassis as far as it will go.
      Frag FixBot
    2. LG Front Load Washing Machine Dampers Replacement: Schritt 6, Bild 1 von 3 LG Front Load Washing Machine Dampers Replacement: Schritt 6, Bild 2 von 3 LG Front Load Washing Machine Dampers Replacement: Schritt 6, Bild 3 von 3
      • Press down on the "Push" button to disengage the clips securing the detergent drawer.
      • Pull the drawer out of its slot on the chassis and remove it.
      Frag FixBot
    1. LG Front Load Washing Machine Dampers Replacement, Disconnect the control panel: Schritt 7, Bild 1 von 3 LG Front Load Washing Machine Dampers Replacement, Disconnect the control panel: Schritt 7, Bild 2 von 3 LG Front Load Washing Machine Dampers Replacement, Disconnect the control panel: Schritt 7, Bild 3 von 3
      • Disconnect the connectors attached to the control panel.
      • Always grip cables by their connectors and not the wires themselves.
      Frag FixBot
    2. LG Front Load Washing Machine Dampers Replacement, Unfasten the control panel: Schritt 8, Bild 1 von 2 LG Front Load Washing Machine Dampers Replacement, Unfasten the control panel: Schritt 8, Bild 2 von 2
      • Remove the screw(s) securing the control panel to the top edge of the chassis.
      Frag FixBot
    3. LG Front Load Washing Machine Dampers Replacement, Unfasten the detergent dispenser: Schritt 9, Bild 1 von 1
      • Remove the screw(s) securing the detergent dispenser.
      Frag FixBot
    4. LG Front Load Washing Machine Dampers Replacement, Unclip the control panel: Schritt 10, Bild 1 von 3 LG Front Load Washing Machine Dampers Replacement, Unclip the control panel: Schritt 10, Bild 2 von 3 LG Front Load Washing Machine Dampers Replacement, Unclip the control panel: Schritt 10, Bild 3 von 3
      • Use a flathead screwdriver, or a pry tool, to unclip the control panel from the chassis.
      Frag FixBot
    5. LG Front Load Washing Machine Dampers Replacement, Remove the control panel: Schritt 11, Bild 1 von 3 LG Front Load Washing Machine Dampers Replacement, Remove the control panel: Schritt 11, Bild 2 von 3 LG Front Load Washing Machine Dampers Replacement, Remove the control panel: Schritt 11, Bild 3 von 3
      • Remove the control panel, making sure to thread any cables through the chassis.
      Frag FixBot
    1. LG Front Load Washing Machine Dampers Replacement, Open the door: Schritt 12, Bild 1 von 2 LG Front Load Washing Machine Dampers Replacement, Open the door: Schritt 12, Bild 2 von 2
      • Open the front door completely.
      Frag FixBot
    2. LG Front Load Washing Machine Dampers Replacement, Remove the boot ring: Schritt 13, Bild 1 von 3 LG Front Load Washing Machine Dampers Replacement, Remove the boot ring: Schritt 13, Bild 2 von 3 LG Front Load Washing Machine Dampers Replacement, Remove the boot ring: Schritt 13, Bild 3 von 3
      • Use needle nose pliers to grip the spring end of the metal ring at the bottom of the rubber boot.
      • Pull the ring away from the chassis to separate it from the boot.
      Frag FixBot
    3. LG Front Load Washing Machine Dampers Replacement: Schritt 14, Bild 1 von 3 LG Front Load Washing Machine Dampers Replacement: Schritt 14, Bild 2 von 3 LG Front Load Washing Machine Dampers Replacement: Schritt 14, Bild 3 von 3
      • Use your hand to completely pull the ring off the boot.
      • During reassembly, perform the following:
      • Insert one end of the ring into its groove along the boot's perimeter.
      • Use pliers to slowly stretch the ring around the boot's perimeter until it's completely nested in its groove.
      • Be sure the spring is centered at the bottom of the boot when you reinstall it.
      • This procedure will take significant force.
      Frag FixBot
    4. LG Front Load Washing Machine Dampers Replacement, Disconnect the boot: Schritt 15, Bild 1 von 3 LG Front Load Washing Machine Dampers Replacement, Disconnect the boot: Schritt 15, Bild 2 von 3 LG Front Load Washing Machine Dampers Replacement, Disconnect the boot: Schritt 15, Bild 3 von 3
      • Use your fingers to pull the boot off its lip on the front panel.
      Frag FixBot
    5. LG Front Load Washing Machine Dampers Replacement: Schritt 16, Bild 1 von 3 LG Front Load Washing Machine Dampers Replacement: Schritt 16, Bild 2 von 3 LG Front Load Washing Machine Dampers Replacement: Schritt 16, Bild 3 von 3
      • Slide your fingers around the lip of the boot until it's completely separated from the panel.
      Frag FixBot
    6. LG Front Load Washing Machine Dampers Replacement, Remove the filter panel: Schritt 17, Bild 1 von 3 LG Front Load Washing Machine Dampers Replacement, Remove the filter panel: Schritt 17, Bild 2 von 3 LG Front Load Washing Machine Dampers Replacement, Remove the filter panel: Schritt 17, Bild 3 von 3
      • Open the filter panel at the bottom of the front panel.
      • Unclip the filter panel.
      Frag FixBot
    7. LG Front Load Washing Machine Dampers Replacement, Drain the machine: Schritt 18, Bild 1 von 3 LG Front Load Washing Machine Dampers Replacement, Drain the machine: Schritt 18, Bild 2 von 3 LG Front Load Washing Machine Dampers Replacement, Drain the machine: Schritt 18, Bild 3 von 3
      • Generally, you should drain your machine when you are repairing the pumps or any hoses leading to or from them.
      • Place a bowl next to the machine.
      • Pull the drain filter hose out of its slot in the chassis enough to lay over the bowl.
      • Remove the plug at the end of the drain filter hose to release excess water into the bowl.
      • During reassembly, re-plug the drain filter hose and thread it back through its slot in the chassis.
      Frag FixBot
    8. LG Front Load Washing Machine Dampers Replacement, Unfasten the filter trim: Schritt 19, Bild 1 von 1
      • Remove the screw(s) securing the filter trim.
      Frag FixBot
    9. LG Front Load Washing Machine Dampers Replacement, Remove the filter trim: Schritt 20, Bild 1 von 2 LG Front Load Washing Machine Dampers Replacement, Remove the filter trim: Schritt 20, Bild 2 von 2
      • Pull the filter trim straight off the front panel to remove it.
      Frag FixBot
    10. LG Front Load Washing Machine Dampers Replacement, Unfasten the lower front panel: Schritt 21, Bild 1 von 1
      • Remove the screw(s) securing the lower front panel.
      Frag FixBot
    11. LG Front Load Washing Machine Dampers Replacement, Unfasten the door latch: Schritt 22, Bild 1 von 1
      • Remove the screw(s) securing the door latch.
      Frag FixBot
    12. LG Front Load Washing Machine Dampers Replacement, Remove the door latch: Schritt 23, Bild 1 von 3 LG Front Load Washing Machine Dampers Replacement, Remove the door latch: Schritt 23, Bild 2 von 3 LG Front Load Washing Machine Dampers Replacement, Remove the door latch: Schritt 23, Bild 3 von 3
      • Pull the door latch through its slot in the chassis and let it hang on its wire.
      Frag FixBot
    13. LG Front Load Washing Machine Dampers Replacement, Unfasten the front panel: Schritt 24, Bild 1 von 3 LG Front Load Washing Machine Dampers Replacement, Unfasten the front panel: Schritt 24, Bild 2 von 3 LG Front Load Washing Machine Dampers Replacement, Unfasten the front panel: Schritt 24, Bild 3 von 3
      • Hold the front panel against the chassis while performing this step to prevent it from falling.
      • Remove the screw(s) securing the front panel.
      Frag FixBot
    14. LG Front Load Washing Machine Dampers Replacement, Remove the front panel: Schritt 25, Bild 1 von 3 LG Front Load Washing Machine Dampers Replacement, Remove the front panel: Schritt 25, Bild 2 von 3 LG Front Load Washing Machine Dampers Replacement, Remove the front panel: Schritt 25, Bild 3 von 3
      • Lift the front panel upward to separate it from its clips on the bottom of the chassis.
      • Pull the front panel away from the chassis to completely separate the front panel.
      Frag FixBot
    15. LG Front Load Washing Machine Dampers Replacement: Schritt 26, Bild 1 von 1
      • Remove the front panel.
      Frag FixBot
    1. LG Front Load Washing Machine Dampers Replacement, Unfasten the rear panel: Schritt 27, Bild 1 von 3 LG Front Load Washing Machine Dampers Replacement, Unfasten the rear panel: Schritt 27, Bild 2 von 3 LG Front Load Washing Machine Dampers Replacement, Unfasten the rear panel: Schritt 27, Bild 3 von 3
      • Remove the screw(s) securing the rear panel.
      Frag FixBot
    2. LG Front Load Washing Machine Dampers Replacement, Remove the rear panel: Schritt 28, Bild 1 von 3 LG Front Load Washing Machine Dampers Replacement, Remove the rear panel: Schritt 28, Bild 2 von 3 LG Front Load Washing Machine Dampers Replacement, Remove the rear panel: Schritt 28, Bild 3 von 3
      • Unclip the rear panel from the chassis.
      Frag FixBot
    3. LG Front Load Washing Machine Dampers Replacement: Schritt 29, Bild 1 von 1
      • Remove the rear panel.
      Frag FixBot
    1. LG Front Load Washing Machine Dampers Replacement, Disconnect the plastic pins: Schritt 30, Bild 1 von 3 LG Front Load Washing Machine Dampers Replacement, Disconnect the plastic pins: Schritt 30, Bild 2 von 3 LG Front Load Washing Machine Dampers Replacement, Disconnect the plastic pins: Schritt 30, Bild 3 von 3
      • Depending on your repair, you might need to access the dampers from the rear, the front, or both ends of the device. Choose whichever method works best for you.
      • Use a flathead screwdriver to press down on the tab securing the plastic pin.
      • You can also used an appropriately-sized box wrench to compress the pins.
      • Use a hammer to tap the pin out of its hole, still making sure the tab is compressed.
      • Repeat this procedure until the pin is loose enough to be removed with your hands.
      Frag FixBot
    2. LG Front Load Washing Machine Dampers Replacement, Remove the plastic pin: Schritt 31, Bild 1 von 2 LG Front Load Washing Machine Dampers Replacement, Remove the plastic pin: Schritt 31, Bild 2 von 2
      • Remove the plastic pin.
      • Repeat these two steps for the second pin on the damper.
      • If your replacement dampers don't come with new pins, apply silicone grease to the old pins during reassembly.
      Frag FixBot
    3. LG Front Load Washing Machine Dampers Replacement, Remove the damper: Schritt 32, Bild 1 von 3 LG Front Load Washing Machine Dampers Replacement, Remove the damper: Schritt 32, Bild 2 von 3 LG Front Load Washing Machine Dampers Replacement, Remove the damper: Schritt 32, Bild 3 von 3
      • Slide the damper out of its slot in the chassis to disconnect it.
      • Remove the damper.
      • If you're having difficulty removing the damper, compress it to shorten its length.
      • Repeat the last two steps for each damper you want to replace.
      Frag FixBot
Abschluss
Repair didn’t go as planned? Ask our Answers community for help.
Eine weitere Person hat diese Anleitung absolviert.
Bill Gilbert
40.177 Reputation
261 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
123 Mitglieder
61.352 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 11
Letzte 7 Tage: 49
Letzte 30 Tage: 217
Insgesamt: 4,042
