Zum Hauptinhalt wechseln
LG Front Load Washing Machine Door Latch Replacement
Was du brauchst
    1. LG Front Load Washing Machine Door Latch Replacement, Safety Precautions: Schritt 1, Bild 1 von 2 LG Front Load Washing Machine Door Latch Replacement, Safety Precautions: Schritt 1, Bild 2 von 2
      • Before you begin your repair, perform the following:
      • Turn off the main water supply
      • Unplug your washer
      • Disconnect all water connections at the rear of your washer
      Frag FixBot
      Kommentar hinzufügen
    1. LG Front Load Washing Machine Door Latch Replacement, Open the door: Schritt 2, Bild 1 von 2 LG Front Load Washing Machine Door Latch Replacement, Open the door: Schritt 2, Bild 2 von 2
      • Open the front door completely.
      Frag FixBot
    2. LG Front Load Washing Machine Door Latch Replacement, Remove the boot ring: Schritt 3, Bild 1 von 3 LG Front Load Washing Machine Door Latch Replacement, Remove the boot ring: Schritt 3, Bild 2 von 3 LG Front Load Washing Machine Door Latch Replacement, Remove the boot ring: Schritt 3, Bild 3 von 3
      • Use needle nose pliers to grip the spring end of the metal ring at the bottom of the rubber boot.
      • Pull the ring away from the chassis to separate it from the boot.
      Frag FixBot
    3. LG Front Load Washing Machine Door Latch Replacement: Schritt 4, Bild 1 von 3 LG Front Load Washing Machine Door Latch Replacement: Schritt 4, Bild 2 von 3 LG Front Load Washing Machine Door Latch Replacement: Schritt 4, Bild 3 von 3
      • Use your hand to completely pull the ring off the boot.
      • During reassembly, perform the following:
      • Insert one end of the ring into its groove along the boot's perimeter.
      • Use pliers to slowly stretch the ring around the boot's perimeter until it's completely nested in its groove.
      • Be sure the spring is centered at the bottom of the boot when you reinstall it.
      • This procedure will take significant force.
      Frag FixBot
    4. LG Front Load Washing Machine Door Latch Replacement, Disconnect the boot: Schritt 5, Bild 1 von 3 LG Front Load Washing Machine Door Latch Replacement, Disconnect the boot: Schritt 5, Bild 2 von 3 LG Front Load Washing Machine Door Latch Replacement, Disconnect the boot: Schritt 5, Bild 3 von 3
      • Use your fingers to pull the boot off its lip in the front panel.
      Frag FixBot
    5. LG Front Load Washing Machine Door Latch Replacement: Schritt 6, Bild 1 von 3 LG Front Load Washing Machine Door Latch Replacement: Schritt 6, Bild 2 von 3 LG Front Load Washing Machine Door Latch Replacement: Schritt 6, Bild 3 von 3
      • Work your fingers around the boot's perimeter until it's completely separated from the panel.
      Frag FixBot
    6. LG Front Load Washing Machine Door Latch Replacement: Schritt 7, Bild 1 von 2 LG Front Load Washing Machine Door Latch Replacement: Schritt 7, Bild 2 von 2
      • Use your hands to fold the boot into the drum.
      Frag FixBot
    7. LG Front Load Washing Machine Door Latch Replacement, Unfasten the door latch: Schritt 8, Bild 1 von 1
      • Remove the screw(s) securing the door latch.
      Frag FixBot
    8. LG Front Load Washing Machine Door Latch Replacement, Expose the door latch: Schritt 9, Bild 1 von 3 LG Front Load Washing Machine Door Latch Replacement, Expose the door latch: Schritt 9, Bild 2 von 3 LG Front Load Washing Machine Door Latch Replacement, Expose the door latch: Schritt 9, Bild 3 von 3
      • Reach between the boot and the chassis to grip the door latch.
      • Pull the door latch out of its slot in the chassis to expose it.
      • Don't try to fully remove the door latch yet. It's still connected to a cable harness.
      Frag FixBot
    9. LG Front Load Washing Machine Door Latch Replacement, Remove the door latch: Schritt 10, Bild 1 von 2 LG Front Load Washing Machine Door Latch Replacement, Remove the door latch: Schritt 10, Bild 2 von 2
      • Disconnect the cable harness from the door latch.
      • Always grip cables by their connectors and not the wires themselves.
      • Remove the door latch.
      Frag FixBot
Abschluss
Repair didn’t go as planned? Ask our Answers community for help.
3 weitere Personen haben diese Anleitung absolviert.
Bill Gilbert
40.177 Reputation
261 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
123 Mitglieder
61.359 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 81
Letzte 30 Tage: 369
Insgesamt: 11,144
