Zum Hauptinhalt wechseln
LG Front Load Washing Machine Rotor Replacement
Was du brauchst
    1. LG Front Load Washing Machine Rotor Replacement, Safety Precautions: Schritt 1, Bild 1 von 2 LG Front Load Washing Machine Rotor Replacement, Safety Precautions: Schritt 1, Bild 2 von 2
      • Before you begin your repair, perform the following:
      • Turn off the main water supply
      • Unplug your washer
      • Disconnect all water connections at the rear of your washer
      Frag FixBot
      Kommentar hinzufügen
    1. LG Front Load Washing Machine Rotor Replacement, Unfasten the rear panel: Schritt 2, Bild 1 von 3 LG Front Load Washing Machine Rotor Replacement, Unfasten the rear panel: Schritt 2, Bild 2 von 3 LG Front Load Washing Machine Rotor Replacement, Unfasten the rear panel: Schritt 2, Bild 3 von 3
      • Remove the screw(s) securing the rear panel.
      Frag FixBot
    2. LG Front Load Washing Machine Rotor Replacement, Remove the rear panel: Schritt 3, Bild 1 von 3 LG Front Load Washing Machine Rotor Replacement, Remove the rear panel: Schritt 3, Bild 2 von 3 LG Front Load Washing Machine Rotor Replacement, Remove the rear panel: Schritt 3, Bild 3 von 3
      • Unclip the rear panel from the chassis.
      Frag FixBot
    3. LG Front Load Washing Machine Rotor Replacement: Schritt 4, Bild 1 von 1
      • Remove the rear panel.
      Frag FixBot
    1. LG Front Load Washing Machine Rotor Replacement, Unfasten the rotor: Schritt 5, Bild 1 von 2 LG Front Load Washing Machine Rotor Replacement, Unfasten the rotor: Schritt 5, Bild 2 von 2
      • Use an impact driver to remove the 17 mm nut securing the rotor.
      • Alternatively, you can use a wrench and a hammer to loosen the nut.
      • To secure the rotor, you can insert a screwdriver, or a similar tool, between the rotor and the stator. Make sure to brace the tool against one of the screw bosses on the stator.
      Frag FixBot
    2. LG Front Load Washing Machine Rotor Replacement, Remove the rotor: Schritt 6, Bild 1 von 2 LG Front Load Washing Machine Rotor Replacement, Remove the rotor: Schritt 6, Bild 2 von 2
      • The rotor is magnetically attracted to the stator.
      • Pull the rotor straight off the stator and drive shaft splines to remove it.
      • Wiggle the rotor as you pull to help disconnect it.
      • This may require significant force.
      • During reassembly, watch your fingers when aligning the rotor over the stator, as the rotor gets sucked in easily.
      Frag FixBot
Abschluss
Repair didn’t go as planned? Ask our Answers community for help.
2 weitere Personen haben diese Anleitung absolviert.
Bill Gilbert
40.207 Reputation
261 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
123 Mitglieder
66.115 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 23
Letzte 30 Tage: 106
Insgesamt: 2,379
