Zum Hauptinhalt wechseln
LG Refrigerator Compressor Run Capacitor Replacement
Was du brauchst
  1. LG Refrigerator Compressor Run Capacitor Replacement, Unplug your refrigerator: Schritt 1, Bild 1 von 1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. LG Refrigerator Compressor Run Capacitor Replacement, Unfasten the control board cover: Schritt 2, Bild 1 von 1
    • Use a Phillips screwdriver to remove the screws securing the control board cover.
  3. LG Refrigerator Compressor Run Capacitor Replacement, Remove the control board cover: Schritt 3, Bild 1 von 3 LG Refrigerator Compressor Run Capacitor Replacement, Remove the control board cover: Schritt 3, Bild 2 von 3 LG Refrigerator Compressor Run Capacitor Replacement, Remove the control board cover: Schritt 3, Bild 3 von 3
    • Tilt the top edge of the cover toward you and lift it off.
  4. LG Refrigerator Compressor Run Capacitor Replacement, Unclip the capacitor: Schritt 4, Bild 1 von 3 LG Refrigerator Compressor Run Capacitor Replacement, Unclip the capacitor: Schritt 4, Bild 2 von 3 LG Refrigerator Compressor Run Capacitor Replacement, Unclip the capacitor: Schritt 4, Bild 3 von 3
    • Pull the left edge of the capacitor toward you to unclip it.
    • Handle the capacitor carefully as it may still be charged, and can give a dangerous and painful electrical shock. Avoid touching the terminals with your fingers or hands.
    • For information on capacitor safety, click here.
  5. LG Refrigerator Compressor Run Capacitor Replacement, Disconnect the capacitor: Schritt 5, Bild 1 von 3 LG Refrigerator Compressor Run Capacitor Replacement, Disconnect the capacitor: Schritt 5, Bild 2 von 3 LG Refrigerator Compressor Run Capacitor Replacement, Disconnect the capacitor: Schritt 5, Bild 3 von 3
    • Pull the connector straight off the capacitor to disconnect it.
    • Remove the capacitor.
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
30.088 Reputation
213 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
136 Mitglieder
17.430 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 29
Letzte 30 Tage: 116
Insgesamt: 340
