Einleitung
This guide will show how to remove the battery for the Lenovo 100s Chromebook-11IBY. This removal will allow you to replace or upgrade the battery for your laptop.
Was du brauchst
Use a Phillips #0 screwdriver to remove the nine 6mm screws from the larger back plate.
Turn your laptop back over, open it, and use the plastic opening tool on the recessed notch to gently pry each side and lift the keyboard plate up.
Unlock the keyboard ZIF connector to release the keyboard flex cable.
Unlock the touchpad ZIF connector to release the touchpad flex cable.
Carefully pull both flex cables out of the ZIF connectors.
Remove the keyboard plate up and place it to the side.
Use the Phillips #0 screwdriver to remove the three 6mm screws from the battery.
For optimal performance, after completing this guide, calibrate your newly installed battery.
2 weitere Personen haben diese Anleitung absolviert.
