Zum Hauptinhalt wechseln
Lenovo IdeaPad 310-15IKB Motherboard Replacement
Was du brauchst
  1. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Unfasten the lower case: Schritt 1, Bild 1 von 2 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Unfasten the lower case: Schritt 1, Bild 2 von 2
    • Flip the laptop over with the hinge facing away from you.
    • Use a Phillips screwdriver to remove the twelve 6.5 mm screws that secure the lower case and the right panel.
    • It's not necessary to remove the lower left panel unless you intend to replace the HDD.
  2. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Remove the right panel: Schritt 2, Bild 1 von 3 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Remove the right panel: Schritt 2, Bild 2 von 3 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Remove the right panel: Schritt 2, Bild 3 von 3
    • Insert the flat end of a spudger into the notch on the upper left corner of the right panel.
    • Pry the panel up to release the retaining clips that secure the panel.
    • Remove the panel.
  3. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Unfasten the motherboard: Schritt 3, Bild 1 von 1
    • Use a Phillips screwdriver to remove the three 6.6 mm screws that secure the motherboard to the lower case.
  4. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the fan cable: Schritt 4, Bild 1 von 2 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the fan cable: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Use tweezers or your fingernails to lift the fan cable connector directly up and out of its motherboard socket.
  5. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Release the ZIF connectors: Schritt 5, Bild 1 von 3 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Release the ZIF connectors: Schritt 5, Bild 2 von 3 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Release the ZIF connectors: Schritt 5, Bild 3 von 3
    • Use the flat end of a spudger or a fingernail to flip up the ZIF locking flaps on the keyboard and trackpad connectors.
  6. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the keyboard ribbon cable: Schritt 6, Bild 1 von 3 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the keyboard ribbon cable: Schritt 6, Bild 2 von 3 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the keyboard ribbon cable: Schritt 6, Bild 3 von 3
    • Use blunt tweezers to pull the keyboard ribbon cable directly out of its socket.
  7. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the trackpad ribbon cable: Schritt 7, Bild 1 von 2 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the trackpad ribbon cable: Schritt 7, Bild 2 von 2
    • Use blunt tweezers to pull the trackpad ribbon cable directly out of its port.
    • Grip and pull the blue pull tab, not the entire ribbon cable.
  8. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the wireless card cables: Schritt 8, Bild 1 von 3 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the wireless card cables: Schritt 8, Bild 2 von 3 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the wireless card cables: Schritt 8, Bild 3 von 3
    • Use the pointed tip of a spudger to gently pry up and disconnect the two antenna cables from the wireless card.
  9. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Open the laptop lid: Schritt 9, Bild 1 von 2 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Open the laptop lid: Schritt 9, Bild 2 von 2
    • Flip the laptop over and open the lid.
  10. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Unclip the left edge: Schritt 10, Bild 1 von 3 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Unclip the left edge: Schritt 10, Bild 2 von 3 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Unclip the left edge: Schritt 10, Bild 3 von 3
    • The keyboard assembly is secured to the lower case by plastic retaining clips. You'll hear and feel them release as you work.
    • Insert the tip of an opening pick into the seam between the top left corner of the lower case and keyboard assembly.
    • Slide the opening pick down to the bottom left corner to release the clips.
  11. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Unclip the front edge: Schritt 11, Bild 1 von 3 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Unclip the front edge: Schritt 11, Bild 2 von 3 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Unclip the front edge: Schritt 11, Bild 3 von 3
    • Insert the tip of an opening pick into the seam between the lower left side of the palm rest and the lower case.
    • Slide the opening pick to the right to release the clips that secure the front edge.
  12. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Unclip the right edge: Schritt 12, Bild 1 von 3 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Unclip the right edge: Schritt 12, Bild 2 von 3 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Unclip the right edge: Schritt 12, Bild 3 von 3
    • Insert the tip of an opening pick into the bottom right seam between the chassis and keyboard assembly.
    • Slide the pick toward the top right corner to release the remaining retaining clips.
  13. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Remove the keyboard assembly: Schritt 13, Bild 1 von 3 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Remove the keyboard assembly: Schritt 13, Bild 2 von 3 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Remove the keyboard assembly: Schritt 13, Bild 3 von 3
    • Lift the keyboard assembly off of the chassis.
  14. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the battery: Schritt 14, Bild 1 von 3 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the battery: Schritt 14, Bild 2 von 3 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the battery: Schritt 14, Bild 3 von 3
    • Use two opening tools or your fingernails to gently "walk" the battery connector directly out of its motherboard socket.
  15. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Unfasten the motherboard: Schritt 15, Bild 1 von 1
    • Use a Phillips screwdriver to remove the four 3.3 mm screws that secure the motherboard to the lower case.
  16. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Release the display cable ZIF connector: Schritt 16, Bild 1 von 2 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Release the display cable ZIF connector: Schritt 16, Bild 2 von 2
    • Use the flat end of a spudger to flip up the ZIF locking flap that secures the display cable.
  17. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the display cable: Schritt 17, Bild 1 von 2 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the display cable: Schritt 17, Bild 2 von 2
    • Use blunt tweezers to pull the display cable directly out of its motherboard socket.
  18. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Unseat the display cable: Schritt 18, Bild 1 von 3 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Unseat the display cable: Schritt 18, Bild 2 von 3 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Unseat the display cable: Schritt 18, Bild 3 von 3
    • Use blunt tweezers to lift the display cable vertically to unseat it from the motherboard.
    • The display cable is attached to the motherboard with a mild adhesive. Lift gently to avoid damaging the cable.
  19. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the speaker cable: Schritt 19, Bild 1 von 3 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the speaker cable: Schritt 19, Bild 2 von 3 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the speaker cable: Schritt 19, Bild 3 von 3
    • Use the pointed end of a spudger or your fingernails to gently "walk" the speaker cable directly out of its motherboard socket.
  20. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Release the HDD and I/O board ribbon cables: Schritt 20, Bild 1 von 3 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Release the HDD and I/O board ribbon cables: Schritt 20, Bild 2 von 3 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Release the HDD and I/O board ribbon cables: Schritt 20, Bild 3 von 3
    • Use the flat end of a spudger to flip up each of the two ZIF locking flaps that secure the HDD and I/O board ribbon cables to the motherboard.
  21. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the HDD and I/O board ribbon cables: Schritt 21, Bild 1 von 3 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the HDD and I/O board ribbon cables: Schritt 21, Bild 2 von 3 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the HDD and I/O board ribbon cables: Schritt 21, Bild 3 von 3
    • Use blunt tweezers to disconnect the the HDD and I/O board ribbon cables from their motherboard ports.
    • Grip and pull the blue pull tabs, not the entire ribbon cable.
  22. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the optical drive ribbon cable: Schritt 22, Bild 1 von 3 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the optical drive ribbon cable: Schritt 22, Bild 2 von 3 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the optical drive ribbon cable: Schritt 22, Bild 3 von 3
    • Use the flat end of a spudger to flip up the ZIF locking flap that secures the optical drive ribbon cable.
    • Use blunt tweezers to gently pull the optical drive ribbon cable directly out of its motherboard port.
  23. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Remove the motherboard: Schritt 23, Bild 1 von 3 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Remove the motherboard: Schritt 23, Bild 2 von 3 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Remove the motherboard: Schritt 23, Bild 3 von 3
    • Slightly lift the right side of the motherboard.
    • Slide the motherboard a few millimeters to the right to unseat the ports from the lower case.
    • Grasp both sides of the motherboard and lift it up and out.
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting, or ask our answers community for help.
Connor Bassolino
20.659 Reputation
98 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
124 Mitglieder
24.130 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 47
Insgesamt: 1,378
