Einleitung
If your Lenovo Legion Y530-15ICH isn’t powering on or holding a charge then you should use this guide to replace the battery.
The battery provides power to the rest of the computer. If your computer won’t power on, you may have a faulty power cord or just need to restart your computer. Your problem may be due to a faulty battery or your battery may also be swollen.
Please make sure the laptop is powered off completely and unplugged before beginning.
Was du brauchst
Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
Five 7 mm screws
Six 4 mm screws
Use a Phillips screwdriver to remove the five 4 mm screws holding the battery in place.
Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
For optimal performance, after completing this guide, calibrate your newly installed battery.
8 weitere Personen haben diese Anleitung absolviert.
5 Kommentare
Hello! I have a Lenovo Y530 laptop and its battery is swollen. After removing the battery and waiting for the replacement, can I directly plug in the laptop to the power without having the battery?
Hi Joshua,
Yes! Be careful to reassemble everything other than the laptop. The laptop should boot, though depending on the brand and model, some will refuse without a battery.
dobry den mohu notebook zn. Lenovo Legion y530 zapnout i kdyz vytahnu baterii?dekuji
你好,Roman。我的Lenovo Legion y530电池鼓包后可以正常使用,直到有一天关机后,接通电源适配器的情况下电脑后面的指示灯不亮了,按开机键也无法开机,于是我知道是时候换电池了。取出电池后发现它严重鼓包,最厚处为正常情况下的3到4倍。取出电池合上后盖后插电源没有反应无法开机,我当时以为电脑主板坏了。如果你遇到以上问题,请不要担心,正常使用不跌落不进水的情况下电脑应该没有坏。我给电脑更换新的L17C3PG1电池后,合上后盖,不插电源适配器,长按开机键至少15秒后松开,如此操作大概1分钟就开机了,此时插上电源适配器后就可以正常使用了。记得拧上后盖螺丝。
marxlan -
Lenovo Legion y530电池鼓包会有预兆的,正常没有跌落没有进水的情况下,如果某天你发现触控板没有反应了,那很有可能是因为电池轻微鼓包导致触控板位置的排线被电池鼓包顶起松动了,如果你平时不用触控板可以先等等更换电池(但是我建议尽快更换新电池,以防危险和不必要的损失发生)。在已知自己电脑电池鼓包的情况下,如果有一天发现触控板高于触控板的物理按键,或者电脑高负载使用时屏幕突然全黑,或者桌面突然消失任务管理器重启等异常情况,请抓紧换新电池吧。对于Lenovo Legion y530来说,L17C3PG1、L17C3PG2和L17C3PG3这3种型号的电池是通用的,对于长期接通电源适配器的用户来说没有区别。
