Zum Hauptinhalt wechseln
Lenovo ThinkPad T480s Motherboard Replacement
Was du brauchst
  1. Lenovo ThinkPad T480s Motherboard Replacement, Bottom Cover: Schritt 1, Bild 1 von 2 Lenovo ThinkPad T480s Motherboard Replacement, Bottom Cover: Schritt 1, Bild 2 von 2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s Motherboard Replacement: Schritt 2, Bild 1 von 3 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 2, Bild 2 von 3 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s Motherboard Replacement: Schritt 3, Bild 1 von 2 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s Motherboard Replacement, Battery: Schritt 4, Bild 1 von 2 Lenovo ThinkPad T480s Motherboard Replacement, Battery: Schritt 4, Bild 2 von 2
    • Use the Phillips #1 screwdriver to remove four 4.5mm screws that hold the battery down to the mid frame.
  5. Lenovo ThinkPad T480s Motherboard Replacement: Schritt 5, Bild 1 von 3 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 5, Bild 2 von 3 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Lift the battery near the connector and remove it from the system.
  6. Lenovo ThinkPad T480s Motherboard Replacement, Keyboard: Schritt 6, Bild 1 von 3 Lenovo ThinkPad T480s Motherboard Replacement, Keyboard: Schritt 6, Bild 2 von 3 Lenovo ThinkPad T480s Motherboard Replacement, Keyboard: Schritt 6, Bild 3 von 3
    • Disable the battery, power down, and unplug your device before you begin.
    • Pry the left and right trackpad buttons up with a spudger.
  7. Lenovo ThinkPad T480s Motherboard Replacement: Schritt 7, Bild 1 von 2 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 7, Bild 2 von 2
    • With a Phillips #0 screwdriver, loosen the two captive screws underneath the left and right trackpad buttons.
  8. Lenovo ThinkPad T480s Motherboard Replacement: Schritt 8, Bild 1 von 3 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 8, Bild 2 von 3 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 8, Bild 3 von 3
    • Wedge the spudger under the front edge of the keyboard to push the keyboard toward the back of the system.
    • Lift the front edge of the keyboard up by a few millimeters.
  9. Lenovo ThinkPad T480s Motherboard Replacement: Schritt 9, Bild 1 von 2 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Gently, pull the keyboard out from the bezel and flip it over.
    • It is connected to the keyboard and trackpad cables so be sure not to yank it over to avoid tearing them.
  10. Lenovo ThinkPad T480s Motherboard Replacement: Schritt 10, Bild 1 von 3 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 10, Bild 2 von 3 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 10, Bild 3 von 3
    • Use the spudger to disconnect the trackpad cable from the system.
    • For more information on types of connectors, check out this guide.
  11. Lenovo ThinkPad T480s Motherboard Replacement: Schritt 11, Bild 1 von 3 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 11, Bild 2 von 3 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 11, Bild 3 von 3
    • Use the spudger to disconnect the keyboard cable from the system.
  12. Lenovo ThinkPad T480s Motherboard Replacement: Schritt 12, Bild 1 von 2 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 12, Bild 2 von 2
    • Lift the keyboard off of the palm rest.
  13. Lenovo ThinkPad T480s Motherboard Replacement, SSD: Schritt 13, Bild 1 von 2 Lenovo ThinkPad T480s Motherboard Replacement, SSD: Schritt 13, Bild 2 von 2
    • Use the Phillips #1 screwdriver to remove one 2.8 mm screw securing the SSD.
  14. Lenovo ThinkPad T480s Motherboard Replacement: Schritt 14, Bild 1 von 3 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 14, Bild 2 von 3 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 14, Bild 3 von 3
    • Pull the SSD out of the socket.
  15. Lenovo ThinkPad T480s Motherboard Replacement, RAM: Schritt 15, Bild 1 von 3 Lenovo ThinkPad T480s Motherboard Replacement, RAM: Schritt 15, Bild 2 von 3 Lenovo ThinkPad T480s Motherboard Replacement, RAM: Schritt 15, Bild 3 von 3
    • Pull the plastic film back.
    • Push the clips outward to release the RAM stick.
    • My device doesn't have RAM so you don't see it.
    • The RAM stick will pop out at an angle. Pull the RAM stick out at the same angle.
  16. Lenovo ThinkPad T480s Motherboard Replacement, Wi-Fi Card: Schritt 16, Bild 1 von 3 Lenovo ThinkPad T480s Motherboard Replacement, Wi-Fi Card: Schritt 16, Bild 2 von 3 Lenovo ThinkPad T480s Motherboard Replacement, Wi-Fi Card: Schritt 16, Bild 3 von 3
    • Using the nylon spudger, pop the coaxial antenna wires off the Wi-Fi card.
    • When reassembling, reattach the gray wire closest to the screw and the black wire on the other side of the gray wire.
  17. Lenovo ThinkPad T480s Motherboard Replacement: Schritt 17, Bild 1 von 2 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 17, Bild 2 von 2
    • Use the Phillips #1 screwdriver to remove one 2.8mm screw holding the Wi-Fi card down to the motherboard.
  18. Lenovo ThinkPad T480s Motherboard Replacement: Schritt 18, Bild 1 von 3 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 18, Bild 2 von 3 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 18, Bild 3 von 3
    • Slide the Wi-Fi card out from the slot.
  19. Lenovo ThinkPad T480s Motherboard Replacement, WWAN Card: Schritt 19, Bild 1 von 3 Lenovo ThinkPad T480s Motherboard Replacement, WWAN Card: Schritt 19, Bild 2 von 3 Lenovo ThinkPad T480s Motherboard Replacement, WWAN Card: Schritt 19, Bild 3 von 3
    • Flip the cardboard cover off of the WWAN card.
    • Using the spudger, release the coaxial antenna wires from the WWAN card.
    • When reassembling, reattach the blue wire on the left and the orange wire on the right.
  20. Lenovo ThinkPad T480s Motherboard Replacement: Schritt 20, Bild 1 von 2 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 20, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove one 2.8mm screw.
  21. Lenovo ThinkPad T480s Motherboard Replacement: Schritt 21, Bild 1 von 3 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 21, Bild 2 von 3 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 21, Bild 3 von 3
    • Slide the WWAN card out from the slot.
  22. Lenovo ThinkPad T480s Motherboard Replacement, Fan Assembly: Schritt 22, Bild 1 von 2 Lenovo ThinkPad T480s Motherboard Replacement, Fan Assembly: Schritt 22, Bild 2 von 2
    • Use the spudger to disconnect the fan cable from the motherboard.
  23. Lenovo ThinkPad T480s Motherboard Replacement: Schritt 23, Bild 1 von 2 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 23, Bild 2 von 2
    • Loosen the four captive screws attaching the fan assembly to the motherboard.
    • Do not attempt to remove the captive screws, as forcing them out may strip or damage them.
  24. Lenovo ThinkPad T480s Motherboard Replacement: Schritt 24, Bild 1 von 3 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 24, Bild 2 von 3 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 24, Bild 3 von 3
    • Lift the fan assembly from the system and remove it.
    • Follow our thermal paste application guide before you replace the fan assembly and are ready to reassemble your device.
  25. Lenovo ThinkPad T480s Motherboard Replacement, SIM Card Tray: Schritt 25, Bild 1 von 2 Lenovo ThinkPad T480s Motherboard Replacement, SIM Card Tray: Schritt 25, Bild 2 von 2
    • Insert the SIM eject bit or a paper clip in the hole of the SIM tray to eject it.
    • Remove the SIM tray.
  26. Lenovo ThinkPad T480s Motherboard Replacement, Motherboard: Schritt 26, Bild 1 von 3 Lenovo ThinkPad T480s Motherboard Replacement, Motherboard: Schritt 26, Bild 2 von 3 Lenovo ThinkPad T480s Motherboard Replacement, Motherboard: Schritt 26, Bild 3 von 3
    • Use the spudger to disconnect the LCD cable from the motherboard.
  27. Lenovo ThinkPad T480s Motherboard Replacement: Schritt 27, Bild 1 von 3 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 27, Bild 2 von 3 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 27, Bild 3 von 3
    • Use the spudger to disconnect the camera cable from the motherboard.
  28. Lenovo ThinkPad T480s Motherboard Replacement: Schritt 28, Bild 1 von 3 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 28, Bild 2 von 3 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 28, Bild 3 von 3
    • Remove all antenna cables from their routing.
  29. Lenovo ThinkPad T480s Motherboard Replacement: Schritt 29, Bild 1 von 3 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 29, Bild 2 von 3 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 29, Bild 3 von 3
    • Use the spudger to disconnect the SD card reader/audio card cable from the board.
    • The cable is attached to the board with adhesive so you will need to peel the cable up.
  30. Lenovo ThinkPad T480s Motherboard Replacement: Schritt 30, Bild 1 von 3 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 30, Bild 2 von 3 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 30, Bild 3 von 3
    • Use a connector puller or spudger to disconnect the coin cell battery from the board and pull the cable from the notch.
  31. Lenovo ThinkPad T480s Motherboard Replacement: Schritt 31, Bild 1 von 3 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 31, Bild 2 von 3 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 31, Bild 3 von 3
    • Use the spudger to disconnect the trackpad cable, the Hall sensor cable, and the smart card reader cable from the motherboard.
  32. Lenovo ThinkPad T480s Motherboard Replacement: Schritt 32, Bild 1 von 3 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 32, Bild 2 von 3 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 32, Bild 3 von 3
    • Disconnect the USB Card cable from the motherboard using the spudger.
  33. Lenovo ThinkPad T480s Motherboard Replacement: Schritt 33, Bild 1 von 2 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 33, Bild 2 von 2
    • Use the spudger to disconnect the power button cable from the motherboard.
  34. Lenovo ThinkPad T480s Motherboard Replacement: Schritt 34, Bild 1 von 2 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 34, Bild 2 von 2
    • Use the Phillips #1 screwdriver to remove the 4.6 mm screw from the USB-C bracket.
  35. Lenovo ThinkPad T480s Motherboard Replacement: Schritt 35, Bild 1 von 2 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 35, Bild 2 von 2
    • Lift the USB-C bracket from the system.
  36. Lenovo ThinkPad T480s Motherboard Replacement: Schritt 36, Bild 1 von 2 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 36, Bild 2 von 2
    • Use the Phillips #1 screwdriver to remove the 4.7 mm screw from the trap door.
  37. Lenovo ThinkPad T480s Motherboard Replacement: Schritt 37, Bild 1 von 2 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 37, Bild 2 von 2
    • Lift the trap door out.
  38. Lenovo ThinkPad T480s Motherboard Replacement: Schritt 38, Bild 1 von 2 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 38, Bild 2 von 2
    • Remove the 4.4 mm screw from the HDMI bracket using the Phillips #1 screwdriver.
  39. Lenovo ThinkPad T480s Motherboard Replacement: Schritt 39, Bild 1 von 3 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 39, Bild 2 von 3 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 39, Bild 3 von 3
    • Remove the HDMI bracket from the motherboard using your fingers.
  40. Lenovo ThinkPad T480s Motherboard Replacement: Schritt 40, Bild 1 von 3 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 40, Bild 2 von 3 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 40, Bild 3 von 3
    • Using the Phillips #1 screwdriver, remove four 3.1 mm screws from the motherboard.
  41. Lenovo ThinkPad T480s Motherboard Replacement: Schritt 41, Bild 1 von 2 Lenovo ThinkPad T480s Motherboard Replacement: Schritt 41, Bild 2 von 2
    • Lift the motherboard from the chassis to remove it from the device.
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
3 weitere Personen haben diese Anleitung absolviert.
Sarah Westberg
37.883 Reputation
71 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
124 Mitglieder
24.293 Anleitungen geschrieben
2 Kommentare zur Anleitung
You saved my life !
Beautiful work, complete, very precise, easy to understand.
Bravo and thank you so much !!!!!!
Keep going this beautiful and so helpful work.
Best!
Louis-Philippe Fourez - Antwort Teilen
Hi @louisphilip8751, thanks for the kind feedback! We're glad the guide helped you successfully complete your repair. Appreciate you taking the time to let us know!
Sarah Westberg - Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 38
Letzte 30 Tage: 176
Insgesamt: 7,111
