Zum Hauptinhalt wechseln
Lenovo ThinkPad T480s Power Button Board Replacement
Was du brauchst
  1. Lenovo ThinkPad T480s Power Button Board Replacement, Bottom Cover: Schritt 1, Bild 1 von 2 Lenovo ThinkPad T480s Power Button Board Replacement, Bottom Cover: Schritt 1, Bild 2 von 2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 2, Bild 1 von 3 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 2, Bild 2 von 3 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 2, Bild 3 von 3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 3, Bild 1 von 2 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 3, Bild 2 von 2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s Power Button Board Replacement, Battery: Schritt 4, Bild 1 von 2 Lenovo ThinkPad T480s Power Button Board Replacement, Battery: Schritt 4, Bild 2 von 2
    • Use the Phillips #1 screwdriver to remove four 4.5mm screws that hold the battery down to the mid frame.
  5. Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 5, Bild 1 von 3 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 5, Bild 2 von 3 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 5, Bild 3 von 3
    • Lift the battery near the connector and remove it from the system.
  6. Lenovo ThinkPad T480s Power Button Board Replacement, Keyboard: Schritt 6, Bild 1 von 3 Lenovo ThinkPad T480s Power Button Board Replacement, Keyboard: Schritt 6, Bild 2 von 3 Lenovo ThinkPad T480s Power Button Board Replacement, Keyboard: Schritt 6, Bild 3 von 3
    • Disable the battery, power down, and unplug your device before you begin.
    • Pry the left and right trackpad buttons up with a spudger.
  7. Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 7, Bild 1 von 2 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 7, Bild 2 von 2
    • With a Phillips #0 screwdriver, loosen the two captive screws underneath the left and right trackpad buttons.
  8. Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 8, Bild 1 von 3 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 8, Bild 2 von 3 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 8, Bild 3 von 3
    • Wedge the spudger under the front edge of the keyboard to push the keyboard toward the back of the system.
    • Lift the front edge of the keyboard up by a few millimeters.
  9. Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 9, Bild 1 von 2 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 9, Bild 2 von 2
    • Gently, pull the keyboard out from the bezel and flip it over.
    • It is connected to to the keyboard and trackpad cables so be sure not to yank it over to avoid tearing them.
  10. Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 10, Bild 1 von 3 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 10, Bild 2 von 3 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 10, Bild 3 von 3
    • Use the spudger to disconnect the trackpad cable from the system.
    • For more information on types of connectors, check out this guide.
  11. Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 11, Bild 1 von 3 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 11, Bild 2 von 3 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 11, Bild 3 von 3
    • Use the spudger to disconnect the keyboard cable from the system.
  12. Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 12, Bild 1 von 2 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 12, Bild 2 von 2
    • Lift the keyboard off of the palm rest.
  13. Lenovo ThinkPad T480s Power Button Board Replacement, SSD: Schritt 13, Bild 1 von 2 Lenovo ThinkPad T480s Power Button Board Replacement, SSD: Schritt 13, Bild 2 von 2
    • Use the Phillips #1 screwdriver to remove one 2.8 mm screw securing the SSD.
  14. Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 14, Bild 1 von 3 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 14, Bild 2 von 3 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 14, Bild 3 von 3
    • Pull the SSD out of the socket.
  15. Lenovo ThinkPad T480s Power Button Board Replacement, RAM: Schritt 15, Bild 1 von 3 Lenovo ThinkPad T480s Power Button Board Replacement, RAM: Schritt 15, Bild 2 von 3 Lenovo ThinkPad T480s Power Button Board Replacement, RAM: Schritt 15, Bild 3 von 3
    • Pull the plastic film back.
    • Push the clips outward to release the RAM stick.
    • My device doesn't have RAM so you don't see it.
    • The RAM stick will pop out at an angle. Pull the RAM stick out at the same angle.
  16. Lenovo ThinkPad T480s Power Button Board Replacement, Wi-Fi Card: Schritt 16, Bild 1 von 3 Lenovo ThinkPad T480s Power Button Board Replacement, Wi-Fi Card: Schritt 16, Bild 2 von 3 Lenovo ThinkPad T480s Power Button Board Replacement, Wi-Fi Card: Schritt 16, Bild 3 von 3
    • Using the nylon spudger, pop the coaxial antenna wires off the Wi-Fi card.
    • When reassembling, reattach the gray wire closest to the screw and the black wire on the other side of the gray wire.
  17. Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 17, Bild 1 von 2 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 17, Bild 2 von 2
    • Use the Phillips #1 screwdriver to remove one 2.8mm screw holding the Wi-Fi card down to the motherboard.
  18. Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 18, Bild 1 von 3 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 18, Bild 2 von 3 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 18, Bild 3 von 3
    • Slide the Wi-Fi card out from the slot.
  19. Lenovo ThinkPad T480s Power Button Board Replacement, WWAN Card: Schritt 19, Bild 1 von 3 Lenovo ThinkPad T480s Power Button Board Replacement, WWAN Card: Schritt 19, Bild 2 von 3 Lenovo ThinkPad T480s Power Button Board Replacement, WWAN Card: Schritt 19, Bild 3 von 3
    • Flip the cardboard cover off of the WWAN card.
    • Using the spudger, release the coaxial antenna wires from the WWAN card.
    • When reassembling, reattach the blue wire on the left and the orange wire on the right.
  20. Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 20, Bild 1 von 2 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 20, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove one 2.8mm screw.
  21. Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 21, Bild 1 von 3 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 21, Bild 2 von 3 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 21, Bild 3 von 3
    • Slide the WWAN card out from the slot.
  22. Lenovo ThinkPad T480s Power Button Board Replacement, Fan Assembly: Schritt 22, Bild 1 von 2 Lenovo ThinkPad T480s Power Button Board Replacement, Fan Assembly: Schritt 22, Bild 2 von 2
    • Use the spudger to disconnect the fan cable from the motherboard.
  23. Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 23, Bild 1 von 2 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 23, Bild 2 von 2
    • Loosen the six captive screws attaching the fan assembly to the motherboard.
    • This system was missing the two screws by the fan but I have highlighted them to show where they are located.
  24. Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 24, Bild 1 von 3 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 24, Bild 2 von 3 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 24, Bild 3 von 3
    • Lift the thermal fan assembly from the system and remove it.
  25. Lenovo ThinkPad T480s Power Button Board Replacement, SIM Card Tray: Schritt 25, Bild 1 von 2 Lenovo ThinkPad T480s Power Button Board Replacement, SIM Card Tray: Schritt 25, Bild 2 von 2
    • Insert the SIM eject bit or a paper clip in the hole of the SIM tray to eject it.
    • Remove the SIM tray.
  26. Lenovo ThinkPad T480s Power Button Board Replacement, Motherboard: Schritt 26, Bild 1 von 3 Lenovo ThinkPad T480s Power Button Board Replacement, Motherboard: Schritt 26, Bild 2 von 3 Lenovo ThinkPad T480s Power Button Board Replacement, Motherboard: Schritt 26, Bild 3 von 3
    • Use the spudger to disconnect the LCD cable from the motherboard.
  27. Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 27, Bild 1 von 3 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 27, Bild 2 von 3 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 27, Bild 3 von 3
    • Use the spudger to disconnect the camera cable from the motherboard.
  28. Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 28, Bild 1 von 3 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 28, Bild 2 von 3 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 28, Bild 3 von 3
    • Remove all antenna cables from their routing.
  29. Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 29, Bild 1 von 3 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 29, Bild 2 von 3 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 29, Bild 3 von 3
    • Use the spudger to disconnect the SD card reader/audio card cable from the board.
    • The cable is attached to the board with adhesive so you will need to peel the cable up.
  30. Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 30, Bild 1 von 3 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 30, Bild 2 von 3 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 30, Bild 3 von 3
    • Use a connector puller or spudger to disconnect the coin cell battery from the board and pull the cable from the notch.
  31. Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 31, Bild 1 von 3 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 31, Bild 2 von 3 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 31, Bild 3 von 3
    • Use the spudger to disconnect the trackpad cable, the Hall sensor cable, and the smart card reader cable from the motherboard.
  32. Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 32, Bild 1 von 3 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 32, Bild 2 von 3 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 32, Bild 3 von 3
    • Disconnect the USB Card cable from the motherboard using the spudger.
  33. Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 33, Bild 1 von 2 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 33, Bild 2 von 2
    • Use the spudger to disconnect the power button cable from the motherboard.
  34. Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 34, Bild 1 von 2 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 34, Bild 2 von 2
    • Use the Phillips #1 screwdriver to remove the 4.6 mm screw from the USB-C bracket.
  35. Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 35, Bild 1 von 2 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 35, Bild 2 von 2
    • Lift the USB-C bracket from the system.
  36. Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 36, Bild 1 von 2 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 36, Bild 2 von 2
    • Use the Phillips #1 screwdriver to remove the 4.7 mm screw from the trap door.
  37. Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 37, Bild 1 von 2 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 37, Bild 2 von 2
    • Lift the trap door out.
  38. Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 38, Bild 1 von 2 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 38, Bild 2 von 2
    • Remove the 4.4 mm screw from the HDMI bracket using the Phillips #1 screwdriver.
  39. Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 39, Bild 1 von 3 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 39, Bild 2 von 3 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 39, Bild 3 von 3
    • Remove the HDMI bracket from the motherboard using your fingers.
  40. Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 40, Bild 1 von 3 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 40, Bild 2 von 3 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 40, Bild 3 von 3
    • Using the Phillips #1 screwdriver, remove four 3.1 mm screws from the motherboard.
  41. Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 41, Bild 1 von 2 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 41, Bild 2 von 2
    • Lift the motherboard from the chassis to remove it from the device.
  42. Lenovo ThinkPad T480s Power Button Board Replacement, Power Button Board: Schritt 42, Bild 1 von 2 Lenovo ThinkPad T480s Power Button Board Replacement, Power Button Board: Schritt 42, Bild 2 von 2
    • Use the Phillips #1 screwdriver to remove a 3 mm screw from the board.
  43. Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 43, Bild 1 von 2 Lenovo ThinkPad T480s Power Button Board Replacement: Schritt 43, Bild 2 von 2
    • Remove the power button board from the system with your fingers.
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Sarah Westberg
23.269 Reputation
70 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
135 Mitglieder
17.277 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 34
Insgesamt: 1,107
