Zum Hauptinhalt wechseln
MacBook Air 13" Early 2015 Left Speaker Replacement
Was du brauchst
  1. MacBook Air 13" Early 2015 Left Speaker Replacement, Lower Case: Schritt 1, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
    Frag FixBot
    Kommentar hinzufügen
  2. MacBook Air 13" Early 2015 Left Speaker Replacement: Schritt 2, Bild 1 von 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    Frag FixBot
  3. MacBook Air 13" Early 2015 Left Speaker Replacement, Battery: Schritt 3, Bild 1 von 1
    • Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
    • Do not lift upward on the connector as you disconnect it.
    Frag FixBot
  4. MacBook Air 13" Early 2015 Left Speaker Replacement: Schritt 4, Bild 1 von 1
    • Remove the following five screws securing the battery to the upper case:
    • Three 6.3 mm T5 Torx screws
    • Two 2.4 mm T5 Torx screws
    Frag FixBot
  5. MacBook Air 13" Early 2015 Left Speaker Replacement: Schritt 5, Bild 1 von 1
    • When handling the battery, avoid squeezing or touching the four exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
    Frag FixBot
  6. MacBook Air 13" Early 2015 Left Speaker Replacement, Left Speaker: Schritt 6, Bild 1 von 1
    • Use the flat end of a spudger to pry the left speaker cable connector up and out of its socket on the I/O board.
    • Pry up from beneath the wires.
    Frag FixBot
  7. MacBook Air 13" Early 2015 Left Speaker Replacement: Schritt 7, Bild 1 von 3 MacBook Air 13" Early 2015 Left Speaker Replacement: Schritt 7, Bild 2 von 3 MacBook Air 13" Early 2015 Left Speaker Replacement: Schritt 7, Bild 3 von 3
    • Use the flat end of a spudger to pry the left speaker off the adhesive securing it to the upper case.
    • Remove the left speaker from the upper case.
    Frag FixBot
Abschluss
7 weitere Personen haben diese Anleitung absolviert.
Sam Goldheart
477.673 Reputation
538 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
123 Mitglieder
27.603 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 77
Insgesamt: 7,152
