Einleitung
Use this guide to replace the entire display assembly on your MacBook Pro, in order to fix a cracked or faulty screen.
For your safety, drain your MacBook Pro's battery below 25% charge before you begin.
Note: Some Torx T3 screws may require a Torx T4 bit to avoid stripping.
Note: After installing a replacement display, your True Tone may not function normally.
Some photos in this guide are from a different model and may contain slight visual discrepancies, but they won't affect the guide procedure.
Was du brauchst
In diesem Schritt verwendetes Werkzeug:Magnetic Project Mat$19.95
If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
Use a P5 Pentalobe driver to remove the six screws securing the lower case:
Two 6.7 mm screws
Four 3.4 mm screws
Apply a suction handle to the lower case near the front-center area of the MacBook Pro.
Lift the suction handle to create a slight gap between the lower case and the chassis.
Insert one corner of an opening pick into the space between the lower case and the chassis.
Slide the opening pick around the nearest corner and halfway up the side of the case.
Repeat the previous step on the opposite side, sliding your opening pick under the lower case and up the side to pop the second clip free.
Insert your opening pick once again under the front edge of the lower case, near one of the two centermost screw holes.
Give the pick a firm twist to pop free the third clip securing the lower case to the chassis.
Repeat this procedure near the other of the two centermost screw holes, popping the fourth clip free.
Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
Pull first at one corner, then the other.
Remove the lower case.
Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
Carefully peel up the large piece of tape covering the battery connector, on the edge of the logic board nearest the battery.
Remove the tape.
Gently peel back the small piece of tape covering the battery board data cable connector.
Use the tip of a spudger to flip up the small black locking tab securing the cable in its connector.
Disconnect the battery board data cable by sliding it out from its socket.
Slide parallel to the logic board, in the direction of the cable.
Use a T5 Torx driver to remove the 3.7 mm pancake screw securing the battery power connector.
Use a spudger to gently lift the battery power connector, disconnecting the battery.
Lift the connector high enough so that it stays separated from its socket. If it accidentally makes contact during the course of your repair, it could damage your MacBook Pro.
Use a T3 Torx driver to remove the four 1.9 mm screws securing the plastic covers on top of the display hinges.
Remove both plastic hinge covers.
Remove the two 2.9 mm T3 Torx screws securing the aluminum cover on top of the main display cable.
Remove the cover.
Remove the two 1.7 mm T3 Torx screws securing the aluminum cover on top of the display cable flex connector.
Remove the cover.
Pry the display board flex cable straight up from its socket to disconnect it from the display board.
Remove the four 3.9 mm T5 Torx screws (two from each side) securing the antenna cable assembly.
Also remove the twelve 1.1 mm P2 pentalobe screws (six from each side).
Carefully disconnect the three antenna coax cables by prying them straight up from the logic board.
Remove the 2.8 mm T5 Torx screw securing the three antenna coax cables to the main board.
Use an opening pick to lever out the antenna cable assembly in the areas shown.
Carefully remove the antenna assembly, while simultaneously feeding the antenna cable bundle out from underneath the heat pipe.
Remove the four 3.9 mm T3 Torx screws securing the two display cable cover springs.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Grab the left side of the display cable assembly and pull it towards the bottom end of the MacBook and away from the cover spring.
Use a pair of tweezers to pull the cover spring of the display cable out of its recess.
Repeat this step with the right cover spring of the display cable assembly.
Fully open your MacBook and gently place it keyboard-side-down on a table so the screen hangs over the edge.
Support the screen with one hand and use your free hand to remove the six T8 Torx screws securing the hinges.
Firmly secure the main body of your MacBook with one hand.
With your free hand, push the left side of the screen up and towards the bottom of your laptop to free the left hinge.
Free the right hinge and remove the screen.
Make sure the screen hinges are fully open and guide them into their recesses in the frame.
Partially tighten the six hinge screws.
Close your laptop and make sure the screen is properly aligned. If it clicks or snaps, readjust the alignment.
Fully tighten the hinge screws.
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
If you are having True Tone, Touch Bar lighting, or keyboard backlight issues after installing a replacement display, try resetting your Mac’s SMC and NVRAM/PRAM.
20 weitere Nutzer:innen haben diese Anleitung absolviert.
11 Kommentare
I'm not sure if I just stripped the screws a bit, but for steps 17 and 19 (the display cable covers), a T4 Torx worked better than a T3 Torx for both removing and reinstalling the screws.
Harry, sometimes a T4 driver may fit better into some MacBook T3 screws, but it depends on the specific bit used and the tolerances on the specific screw in the machine. Thanks for your insight—I'll add a note to the guide!
Did the repair go OK for you? Did the True Tone work at all?
Just finished doing this and when the computer boots the apple logo looks the correct brightness. Halfway through the boot process, the screen gets really dim, even through brightness is set to max. Not sure the cause of this, will report back if I figure it out.
Did you ever figure out what has caused this? I am about to do this repair so wanted to do some research first.
