Einleitung
This guide shows how to remove and replace a worn out thumbgrip on your Meta Quest 2 controller.
The thumbgrip is a rubbery cover and not the actual joystick module. If you're experiencing controller drift, follow this guide instead to replace the joystick module.
This guide is written with the right controller. If you're repairing the left controller, you can still use this guide, as the procedure is identical.
Was du brauchst
Use your fingers to slide the battery cover down towards the strap end of the controller.
Remove the battery cover.
Heat an iOpener and apply it to the bottom edge of the controller faceplate for a minute.
The controller faceplate is secured with adhesive and three friction pegs.
Press the edge of an opening tool into the seam between the controller faceplate and shell, near the Oculus button.
Slide the opening tool to the base of the ring shell to loosen the adhesive.
Continue prying around the entire faceplate to separate the remaining friction pegs and adhesive.
Use your fingers to pull the thumbgrip straight off of the thumbstick and remove it.
