Einleitung
Use this guide to remove or replace the left speaker in your Microsoft Surface Laptop 4 (15-inch).
If your battery is swollen, take appropriate precautions.
Some photos in this guide are from a different model and may contain slight visual discrepancies, but they won't affect the guide procedure.
Was du brauchst
Unplug all cables and fully shut down your laptop.
Close the screen and lay your laptop down with the rear case facing up to access the four rubber feet.
The back feet recesses are closest to the back edge of the laptop.
The front feet recesses are closest to the front edge of the laptop.
Insert one arm of your tweezers into the recess of one of the feet.
Twist your tweezers and pry up to separate the adhesive and unclip the foot from the laptop.
Remove the foot.
Repeat this process on the remaining feet.
The rear feet have a single center clip.
The front feet have three clips and can only be reinserted one way.
If the existing feet no longer adhere to the frame, remove the old adhesive and apply a small amount of Tesa Tape where the old adhesive was.
Peel a pad away from its backing.
Align the pad over a foot cavity and press down to secure it.
Use a T5 Torx driver to remove the four 3 mm screws securing the upper case.
Grip the top edge of the upper case above the keyboard and lift straight up to release it.
Lift the bottom edge of the upper case up and away from the laptop, taking care to not strain the ribbon cable underneath.
Insert the pointed end of a spudger under one edge of the magnet connector and pry up to disconnect it.
Remove the upper case and set it keyboard-side down on a clean surface.
Use a T5 Torx driver to remove the 2.7 mm screw securing the SSD.
Use a T3 Torx driver to remove the 3 mm screw securing the left side of the heatsink, near the left speaker connector.
Use a pair of tweezers or your fingers to lift the left side of the heatsink where you just removed a screw.
While holding the heat sink up, use the pointed end of a spudger to lift and disconnect the left speaker wire from its connector on the motherboard.
Lower the heatsink back into place.
Use a T3 Torx driver to remove the three 2.6 mm screws securing the left speaker.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting or check out our Answers community for help.
