Zum Hauptinhalt wechseln
Motorola Moto E4 Plus Earpiece Speaker Replacement
Was du brauchst
  1. Motorola Moto E4 Plus Earpiece Speaker Replacement, Remove the back cover: Schritt 1, Bild 1 von 3 Motorola Moto E4 Plus Earpiece Speaker Replacement, Remove the back cover: Schritt 1, Bild 2 von 3 Motorola Moto E4 Plus Earpiece Speaker Replacement, Remove the back cover: Schritt 1, Bild 3 von 3
    • Power off your phone before beginning disassembly.
    • Insert the edge of the spudger into the notch on the bottom right corner of the phone.
    • Twist the spudger to start releasing the back cover from the phone.
    • Slide the spudger along the bottom edge to separate the back cover from the phone.
  2. Motorola Moto E4 Plus Earpiece Speaker Replacement: Schritt 2, Bild 1 von 2 Motorola Moto E4 Plus Earpiece Speaker Replacement: Schritt 2, Bild 2 von 2
    • Lift the phone unit out of the back cover.
  3. Motorola Moto E4 Plus Earpiece Speaker Replacement, Remove the midframe screws: Schritt 3, Bild 1 von 1
    • Remove the nineteen 3.2 mm long T3 screws securing the plastic midframe.
  4. Motorola Moto E4 Plus Earpiece Speaker Replacement, Release the midframe clips: Schritt 4, Bild 1 von 2 Motorola Moto E4 Plus Earpiece Speaker Replacement, Release the midframe clips: Schritt 4, Bild 2 von 2
    • The plastic midframe is still held in place with clips.
    • Insert the flat end of a spudger into the midframe seam at the bottom left corner of the phone (near the microphone hole).
    • Twist the spudger to release the plastic clip.
    • Repeat the process for the clip near the top right corner of the phone.
  5. Motorola Moto E4 Plus Earpiece Speaker Replacement, Remove the midframe: Schritt 5, Bild 1 von 2 Motorola Moto E4 Plus Earpiece Speaker Replacement, Remove the midframe: Schritt 5, Bild 2 von 2
    • Lift the bottom edge of the plastic midframe upwards until the clips along the top edge release.
    • Remove the plastic midframe.
    • To reattach the plastic midframe, line up the midframe to the phone and squeeze along the edges to engage the clips.
  6. Motorola Moto E4 Plus Earpiece Speaker Replacement, Disconnect the battery: Schritt 6, Bild 1 von 2 Motorola Moto E4 Plus Earpiece Speaker Replacement, Disconnect the battery: Schritt 6, Bild 2 von 2
    • Use the point of a spudger to pry up and disconnect the battery connector from its motherboard socket.
  7. Motorola Moto E4 Plus Earpiece Speaker Replacement, Loosen the earpiece speaker: Schritt 7, Bild 1 von 2 Motorola Moto E4 Plus Earpiece Speaker Replacement, Loosen the earpiece speaker: Schritt 7, Bild 2 von 2
    • Insert the point of a spudger in the crevice along the right edge of the earpiece speaker.
    • Gently pry up to loosen the earpiece speaker from its recess.
  8. Motorola Moto E4 Plus Earpiece Speaker Replacement, Remove the earpiece speaker: Schritt 8, Bild 1 von 1
    • Remove the earpiece speaker.
    • When you install a replacement module, be sure to orient it properly. The side with the two corner springs should face towards the front-facing camera module.
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Moto E4 Plus Answers community for help.
Eine weitere Person hat diese Anleitung absolviert.
Arthur Shi
257.553 Reputation
529 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
141 Mitglieder
17.903 Anleitungen geschrieben
2 Kommentare
Hi Arthur,
I just replaced the screen on my Moto E4 Plus - XT1775 and I am now getting static from the ear speaker when in speaker mode.
I tried Safe Mode, but that didn’t change anything.
Any ideas, thoughts, or advice would be greatly appreciated.
Thank you,
George
George - Antwort
Hi George,
Does the earpiece sound normal in non-speaker mode? Or does it also not work? I would double-check if the two spring contacts are properly pressing against the pads on the plastic midframe. Make sure that the spring contacts and the pads are clean.
Arthur Shi -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 1,384
