Einleitung
The Motorola Moto G6 features a USB type C charging port. The charging port allows the battery to recharge through an external power source. If the charging port is damaged, it may lead to a damaged battery, or a nonchargeable device. This will require a charging port replacement.
This guide teaches how to perform a charging port replacement. No repair experience is required. However, this replacement will require tools to pry the back shell open, unscrew plates within the device, remove interior pieces, and solder inside of the device. The specific device model in this guide is XT1925-12. Other model numbers include: XT1925-4, XT1925-5, XT1925-6, and XT1925DL.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Before beginning the repair, make sure the device is turned off and disconnected from an external power source. Gather the suggested tools listed below and a new Motorola Moto G6 charging port.
Was du brauchst
If possible, drain the battery before disassembly. When the battery is charged, there's an increased risk of a dangerous thermal event if the battery is overheated or damaged during repairs.
Prepare an iOpener and heat the back of the phone along its bottom edge for about two minutes, or until it's slightly too hot to touch. This will help soften the adhesive securing the rear glass.
Apply a suction cup to the bottom edge of the rear glass.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the rear glass and the frame.
If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools quickly, so you may need to heat it repeatedly.
Insert an opening pick into the gap you created under the rear glass.
Slide the pick all along the bottom edge of the phone to slice through the adhesive securing the rear glass.
Heat the right edge of the back of the phone to soften the adhesive underneath.
Slide the pick along the right edge of the rear glass to separate the adhesive underneath.
Slide the pick all along the top edge of the phone to slice through the adhesive securing the rear glass.
Slide a pick along the left edge of the phone to slice through the rear glass adhesive.
In diesem Schritt verwendetes Werkzeug:Tesa 61395 Tape$5.99
If the glass remains stuck, re-heat and slice the adhesive repeatedly as needed.
Lift the rear glass carefully, making sure it's fully separated from any adhesive.
Remove the rear glass.
Use a pair of tweezers to carefully peel up the black tape covering the battery.
Remove the tape.
Use a Phillips driver to remove seventeen screws securing the plastic cover:
Eleven grey 3 mm-long screws
Five black 2.5 mm-long screws
One silver 3.5 mm-long screw
Insert the pointed end of a spudger into the notch at the top left edge of the plastic cover.
Pry up with the spudger to lift the upper edge of the cover and release the clips holding the cover down.
Remove the plastic cover.
Using the iFixit opening tool, pop up the three press-fit connectors in the bottom right corner of the motherboard.
Using tweezers, pull up the battery connector to remove it from its port in the motherboard.
Use the opening tool to disconnect the press-fit connection on the top left of the motherboard, similar to the previous step.
Use either your fingernail or tweezers to pull the orange boxed connector out. Unlike the other connections, this one is pulled down and not up from the device.
Take off the black rubber cover around the charging port with a pair of tweezers.
Carefully desolder the four pins which physically hold the port in place.
Carefully de-solder the electrical pins which connect the port to the circuit board.
7 weitere Nutzer:innen haben diese Anleitung absolviert.
8 Kommentare
Thanks for the guide, but where can I buy a replacement charging port? I thought the Motorola replacement parts would be available here but I can‘t find it?
Hi! We are currently still in the process of adding Motorola parts into our inventory. Please check back soon!
Awesome guide! I really need to make this repair, is there anyone who knows where I can find a replacement port?
You can find them on eBay.
