Zum Hauptinhalt wechseln
Motorola Moto G6 Charging Port Replacement
Was du brauchst
  1. Motorola Moto G6 Charging Port Replacement, Remove the Rear Glass: Schritt 1, Bild 1 von 1
    • Power your phone off before you begin.
    • If possible, drain the battery before disassembly. When the battery is charged, there's an increased risk of a dangerous thermal event if the battery is overheated or damaged during repairs.
    • If the rear glass is cracked, completely cover it with packing tape to contain the glass shards and avoid injury.
    • Prepare an iOpener and heat the back of the phone along its bottom edge for about two minutes, or until it's slightly too hot to touch. This will help soften the adhesive securing the rear glass.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Motorola Moto G6 Charging Port Replacement: Schritt 2, Bild 1 von 3 Motorola Moto G6 Charging Port Replacement: Schritt 2, Bild 2 von 3 Motorola Moto G6 Charging Port Replacement: Schritt 2, Bild 3 von 3
    • Apply a suction cup to the bottom edge of the rear glass.
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the rear glass and the frame.
    • If the glass is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • This may require a significant amount of force, but you only need to open a very slight gap with the suction cup to insert your tool.
    • If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools quickly, so you may need to heat it repeatedly.
    • Insert an opening pick into the gap you created under the rear glass.
  3. Motorola Moto G6 Charging Port Replacement: Schritt 3, Bild 1 von 3 Motorola Moto G6 Charging Port Replacement: Schritt 3, Bild 2 von 3 Motorola Moto G6 Charging Port Replacement: Schritt 3, Bild 3 von 3
    • Slide the pick all along the bottom edge of the phone to slice through the adhesive securing the rear glass.
    • Slow down and slice very carefully as you get to the corners. The curved part of the glass along the left and right edges can crack very easily if the pick pushes up against the curved glass.
    • After being cut, the adhesive will sometimes stick back together as it cools. To prevent this you can leave the pick in this edge after cutting, and continue the next steps with a new pick. Repeat this with each edge, leaving a pick and continuing with a new one.
  4. Motorola Moto G6 Charging Port Replacement: Schritt 4, Bild 1 von 1
    • Heat the right edge of the back of the phone to soften the adhesive underneath.
  5. Motorola Moto G6 Charging Port Replacement: Schritt 5, Bild 1 von 3 Motorola Moto G6 Charging Port Replacement: Schritt 5, Bild 2 von 3 Motorola Moto G6 Charging Port Replacement: Schritt 5, Bild 3 von 3
    • Slide the pick along the right edge of the rear glass to separate the adhesive underneath.
  6. Motorola Moto G6 Charging Port Replacement: Schritt 6, Bild 1 von 1
    • Heat the top edge of the back of the phone to soften the rear glass adhesive.
  7. Motorola Moto G6 Charging Port Replacement: Schritt 7, Bild 1 von 3 Motorola Moto G6 Charging Port Replacement: Schritt 7, Bild 2 von 3 Motorola Moto G6 Charging Port Replacement: Schritt 7, Bild 3 von 3
    • Slide the pick all along the top edge of the phone to slice through the adhesive securing the rear glass.
  8. Motorola Moto G6 Charging Port Replacement: Schritt 8, Bild 1 von 1
    • Heat the left edge of the back of the phone to soften the adhesive underneath.
  9. Motorola Moto G6 Charging Port Replacement: Schritt 9, Bild 1 von 3 Motorola Moto G6 Charging Port Replacement: Schritt 9, Bild 2 von 3 Motorola Moto G6 Charging Port Replacement: Schritt 9, Bild 3 von 3
    • Slide a pick along the left edge of the phone to slice through the rear glass adhesive.
  10. Motorola Moto G6 Charging Port Replacement: Schritt 10, Bild 1 von 2 Motorola Moto G6 Charging Port Replacement: Schritt 10, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Tesa 61395 Tape
    $8.95
    • If the glass remains stuck, re-heat and slice the adhesive repeatedly as needed.
    • Lift the rear glass carefully, making sure it's fully separated from any adhesive.
    • Remove the rear glass.
    • During reassembly, pause here to replace the adhesive on the rear glass using a precut adhesive card or high-strength double-sided adhesive tape, such as Tesa 61395.
    • After closing your device back up during reassembly, stack something heavy, like a textbook or two, on top of the device for 30-60 minutes. This ensures a strong adhesive bond.
  11. Motorola Moto G6 Charging Port Replacement, Remove the Battery Tape: Schritt 11, Bild 1 von 2 Motorola Moto G6 Charging Port Replacement, Remove the Battery Tape: Schritt 11, Bild 2 von 2
    • Use a pair of tweezers to carefully peel up the black tape covering the battery.
    • Remove the tape.
    • If possible, keep the tape intact so it can be reused during reassembly.
  12. Motorola Moto G6 Charging Port Replacement, Remove the Plastic Cover: Schritt 12, Bild 1 von 1
    • Use a Phillips driver to remove seventeen screws securing the plastic cover:
    • Eleven grey 3 mm-long screws
    • Five black 2.5 mm-long screws
    • One silver 3.5 mm-long screw
  13. Motorola Moto G6 Charging Port Replacement: Schritt 13, Bild 1 von 3 Motorola Moto G6 Charging Port Replacement: Schritt 13, Bild 2 von 3 Motorola Moto G6 Charging Port Replacement: Schritt 13, Bild 3 von 3
    • Insert the pointed end of a spudger into the notch at the top left edge of the plastic cover.
    • Pry up with the spudger to lift the upper edge of the cover and release the clips holding the cover down.
    • Remove the plastic cover.
  14. Motorola Moto G6 Charging Port Replacement, Motherboard: Schritt 14, Bild 1 von 2 Motorola Moto G6 Charging Port Replacement, Motherboard: Schritt 14, Bild 2 von 2
    • Using the iFixit opening tool, pop up the three press-fit connectors in the bottom right corner of the motherboard.
  15. Motorola Moto G6 Charging Port Replacement: Schritt 15, Bild 1 von 3 Motorola Moto G6 Charging Port Replacement: Schritt 15, Bild 2 von 3 Motorola Moto G6 Charging Port Replacement: Schritt 15, Bild 3 von 3
    • Using tweezers, pull up the battery connector to remove it from its port in the motherboard.
    • Before moving on ensure your device has all four the connections undone from the third picture.
  16. Motorola Moto G6 Charging Port Replacement: Schritt 16, Bild 1 von 3 Motorola Moto G6 Charging Port Replacement: Schritt 16, Bild 2 von 3 Motorola Moto G6 Charging Port Replacement: Schritt 16, Bild 3 von 3
    • Use the opening tool to disconnect the press-fit connection on the top left of the motherboard, similar to the previous step.
    • Use either your fingernail or tweezers to pull the orange boxed connector out. Unlike the other connections, this one is pulled down and not up from the device.
  17. Motorola Moto G6 Charging Port Replacement: Schritt 17, Bild 1 von 2 Motorola Moto G6 Charging Port Replacement: Schritt 17, Bild 2 von 2
    • Remove the two black 2.7 mm screws from the motherboard.
  18. Motorola Moto G6 Charging Port Replacement: Schritt 18, Bild 1 von 2 Motorola Moto G6 Charging Port Replacement: Schritt 18, Bild 2 von 2
    • Remove the motherboard out of place.
    • When reassembling your device ensure you set the mother board under all of the connectors and make sure the cameras and the marked red piece remain in place.
  19. Motorola Moto G6 Charging Port Replacement, Charging Port: Schritt 19, Bild 1 von 3 Motorola Moto G6 Charging Port Replacement, Charging Port: Schritt 19, Bild 2 von 3 Motorola Moto G6 Charging Port Replacement, Charging Port: Schritt 19, Bild 3 von 3
    • Take off the black rubber cover around the charging port with a pair of tweezers.
  20. Motorola Moto G6 Charging Port Replacement: Schritt 20, Bild 1 von 2 Motorola Moto G6 Charging Port Replacement: Schritt 20, Bild 2 von 2
    • Carefully desolder the four pins which physically hold the port in place.
    • Carefully de-solder the electrical pins which connect the port to the circuit board.
    • For assistance soldering, check out this soldering guide.
Abschluss
8 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team S11-G1, Regan Fall 2019 Mitglied von Cal Poly, Team S11-G1, Regan Fall 2019
CPSU-REGAN-F19S11G1
4 Mitglieder
14 Anleitungen geschrieben
8 Kommentare zur Anleitung
Thanks for the guide, but where can I buy a replacement charging port? I thought the Motorola replacement parts would be available here but I can‘t find it?
Rik Shaw - Antwort Teilen
Hi! We are currently still in the process of adding Motorola parts into our inventory. Please check back soon!
Arthur Shi - Teilen
Awesome guide! I really need to make this repair, is there anyone who knows where I can find a replacement port?
Benjamin Busby - Antwort Teilen
You can find them on eBay.
David Fear - Teilen
Hi - any updates on adding this part to your inventory? Thanks!
Chris P - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 47
Letzte 30 Tage: 136
Insgesamt: 18,328
