Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Follow this guide to replace a faulty or damaged fan in the Nintendo Switch Lite.
Note: This procedure requires removing the shield plate and heat sink. The thermal paste will need to be cleaned off of both components—as well as the CPU—and reapplied before reinstalling the shield plate and heat sink.
    • Before beginning this repair, make sure that the device is completely turned off.
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the back panel.
  1. Use a Phillips screwdriver to remove the following screws securing the back panel: Two 3.6 mm-long screws on the top of the device
    • Use a Phillips screwdriver to remove the following screws securing the back panel:
    • Two 3.6 mm-long screws on the top of the device
    • Two 3.6 mm-long screws on the bottom of the device
  2. Insert an opening tool into the left speaker grille on the bottom of the device. Twist the opening tool to release the clips securing the back panel.
    • Insert an opening tool into the left speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips securing the back panel.
    • Avoid inserting the opening tool further than required to prevent damage to the speaker module.
  3. Slide the opening tool around the bottom-left corner to release the clips on the left side of the device. Slide the opening tool around the bottom-left corner to release the clips on the left side of the device.
    • Slide the opening tool around the bottom-left corner to release the clips on the left side of the device.
  4. Insert an opening tool into the right speaker grille on the bottom of the device. Twist the opening tool to release the clips.
    • Insert an opening tool into the right speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips.
  5. Slide and pry the opening tool around the bottom-right corner to release the clips on the right side of the device. Slide and pry the opening tool around the bottom-right corner to release the clips on the right side of the device.
    • Slide and pry the opening tool around the bottom-right corner to release the clips on the right side of the device.
  6. Continue sliding and prying the opening tool along the gap on the top of the device to release the clips. Continue sliding and prying the opening tool along the gap on the top of the device to release the clips.
    • Continue sliding and prying the opening tool along the gap on the top of the device to release the clips.
  7. Das Essential Toolkit
    Die nützlichsten Werkzeuge in unserem kompaktesten Kit.
    Jetzt kaufen
    Jetzt kaufen
  8. Lift the bottom edge of the back panel, opening it like a book. Remove the back panel. Remove the back panel.
    • Lift the bottom edge of the back panel, opening it like a book.
    • Remove the back panel.
  9. Use a Phillips screwdriver to remove the following four screws:
    • Use a Phillips screwdriver to remove the following four screws:
    • Three 3.1 mm screws
    • One 4.5 mm screw
  10. Use a spudger or your fingers to lift the shield plate up and out of the device. You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste. Remove the shield plate.
    • Use a spudger or your fingers to lift the shield plate up and out of the device.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • Remove the shield plate.
    • Clean off the old thermal paste from the shield plate and heat sink using isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the heat sink before reassembly.
  11. Use an opening tool or your fingernail to flip up the small, hinged locking flap on the motherboard interconnect cable's ZIF connector. Use an opening tool or your fingernail to flip up the small, hinged locking flap on the motherboard interconnect cable's ZIF connector.
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the motherboard interconnect cable's ZIF connector.
  12. Use a pair of tweezers to slide the interconnect cable out of its connector on the motherboard. Use a pair of tweezers to slide the interconnect cable out of its connector on the motherboard.
    • Use a pair of tweezers to slide the interconnect cable out of its connector on the motherboard.
  13. Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard. Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
    • Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
  14. Use the flat end of a spudger or your fingers to carefully peel up the foam that's lightly adhered to the fan.
    • Use the flat end of a spudger or your fingers to carefully peel up the foam that's lightly adhered to the fan.
    • The foam only needs to be peeled back enough to clear the fan.
  15. Use a Phillips screwdriver to remove the three 3 mm screws securing the heat sink to the motherboard.
    • Use a Phillips screwdriver to remove the three 3 mm screws securing the heat sink to the motherboard.
  16. Use a spudger or your fingers to lift the heatsink up and off of the motherboard to remove it. You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste. Clean off the old thermal paste from the heat sink and CPU using isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly.
    • Use a spudger or your fingers to lift the heatsink up and off of the motherboard to remove it.
    • You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste.
    • Clean off the old thermal paste from the heat sink and CPU using isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly.
  17. Use an opening tool or your fingernail to flip up the small, hinged locking flap on the fan cable's ZIF connector. Use an opening tool or your fingernail to flip up the small, hinged locking flap on the fan cable's ZIF connector.
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the fan cable's ZIF connector.
  18. Use a pair of tweezers to slide out the fan cable from its connector on the motherboard. Use a pair of tweezers to slide out the fan cable from its connector on the motherboard.
    • Use a pair of tweezers to slide out the fan cable from its connector on the motherboard.
  19. Use a Phillips screwdriver to remove the three 4.8 mm screws securing the fan.
    • Use a Phillips screwdriver to remove the three 4.8 mm screws securing the fan.
  20. Remove the fan. Take care not to snag the fan cable on the motherboard as you remove the fan. Take care not to snag the fan cable on the motherboard as you remove the fan.
    • Remove the fan.
    • Take care not to snag the fan cable on the motherboard as you remove the fan.
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Lite Answers community for help.
Craig Lloyd
13.340 Reputation
64 Anleitungen geschrieben
iFixit Mitglied von iFixit
Community
131 Mitglieder
13.424 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 6
Letzten 7 Tage: 47
Letzten 30 Tage: 101
Insgesamt: 269
