Zum Hauptinhalt wechseln
Razer Blade 15" (2019) Right Fan Replacement
Was du brauchst
  1. Razer Blade 15" (2019) Right Fan Replacement, Prepare your laptop for disassembly: Schritt 1, Bild 1 von 2 Razer Blade 15" (2019) Right Fan Replacement, Prepare your laptop for disassembly: Schritt 1, Bild 2 von 2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables, fully shut down your laptop, and close the lid.
  2. Razer Blade 15" (2019) Right Fan Replacement, Unfasten the back cover: Schritt 2, Bild 1 von 1
    • Rotate your laptop so the screen hinge is farthest from you.
    • Use a Torx T5 driver to remove the ten 3.8 mm-long screws securing the back cover.
  3. Razer Blade 15" (2019) Right Fan Replacement, Insert an opening pick: Schritt 3, Bild 1 von 3 Razer Blade 15" (2019) Right Fan Replacement, Insert an opening pick: Schritt 3, Bild 2 von 3 Razer Blade 15" (2019) Right Fan Replacement, Insert an opening pick: Schritt 3, Bild 3 von 3
    • Depending on the age and condition of your laptop, the back cover may come off sooner than this guide instructs. If the cover feels loose, remove it at any time.
    • Apply a suction handle to the right edge of the back cover, between the middle screws and the screws closest to you.
    • Pull up on the suction handle to create a small gap between the back cover and the frame.
    • Insert an opening pick into the gap.
  4. Razer Blade 15" (2019) Right Fan Replacement, Angle the opening pick: Schritt 4, Bild 1 von 3 Razer Blade 15" (2019) Right Fan Replacement, Angle the opening pick: Schritt 4, Bild 2 von 3 Razer Blade 15" (2019) Right Fan Replacement, Angle the opening pick: Schritt 4, Bild 3 von 3
    • Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
    • Insert your pick up to 10 mm (0.4 in) deep.
  5. Razer Blade 15" (2019) Right Fan Replacement, Free the bottom right corner: Schritt 5, Bild 1 von 3 Razer Blade 15" (2019) Right Fan Replacement, Free the bottom right corner: Schritt 5, Bild 2 von 3 Razer Blade 15" (2019) Right Fan Replacement, Free the bottom right corner: Schritt 5, Bild 3 von 3
    • Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
  6. Razer Blade 15" (2019) Right Fan Replacement, Free the front edge: Schritt 6, Bild 1 von 3 Razer Blade 15" (2019) Right Fan Replacement, Free the front edge: Schritt 6, Bild 2 von 3 Razer Blade 15" (2019) Right Fan Replacement, Free the front edge: Schritt 6, Bild 3 von 3
    • Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame.
  7. Razer Blade 15" (2019) Right Fan Replacement, Remove the back cover: Schritt 7, Bild 1 von 3 Razer Blade 15" (2019) Right Fan Replacement, Remove the back cover: Schritt 7, Bild 2 von 3 Razer Blade 15" (2019) Right Fan Replacement, Remove the back cover: Schritt 7, Bild 3 von 3
    • Remove the back cover.
    • Lay the back cover down on its rubber feet to avoid damaging the gray thermal pads on its underside.
  8. Razer Blade 15" (2019) Right Fan Replacement, Soften the battery cable tape adhesive: Schritt 8, Bild 1 von 2 Razer Blade 15" (2019) Right Fan Replacement, Soften the battery cable tape adhesive: Schritt 8, Bild 2 von 2
    • Apply a heated iOpener to the battery cable tape for one minute.
    • You can also use a hair dryer—but be careful, as overheating the battery may damage it or create a fire hazard.
  9. Razer Blade 15" (2019) Right Fan Replacement, Peel up the battery cable tape: Schritt 9, Bild 1 von 3 Razer Blade 15" (2019) Right Fan Replacement, Peel up the battery cable tape: Schritt 9, Bild 2 von 3 Razer Blade 15" (2019) Right Fan Replacement, Peel up the battery cable tape: Schritt 9, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Be careful not to damage the battery with your tool.
    • Use blunt nose tweezers or your fingers to peel the battery cable tape away from the cable.
  10. Razer Blade 15" (2019) Right Fan Replacement, Disconnect the battery: Schritt 10, Bild 1 von 3 Razer Blade 15" (2019) Right Fan Replacement, Disconnect the battery: Schritt 10, Bild 2 von 3 Razer Blade 15" (2019) Right Fan Replacement, Disconnect the battery: Schritt 10, Bild 3 von 3
    • Use the point of a spudger to press on alternating sides of the battery connector and walk it out of its socket.
  11. Razer Blade 15" (2019) Right Fan Replacement, Disconnect the right fan: Schritt 11, Bild 1 von 2 Razer Blade 15" (2019) Right Fan Replacement, Disconnect the right fan: Schritt 11, Bild 2 von 2
    • Use blunt nose tweezers or your fingers to grab the rubber sleeve around the right fan cable and pull the connector straight out of its socket.
  12. Razer Blade 15" (2019) Right Fan Replacement, Disconnect the screen: Schritt 12, Bild 1 von 3 Razer Blade 15" (2019) Right Fan Replacement, Disconnect the screen: Schritt 12, Bild 2 von 3 Razer Blade 15" (2019) Right Fan Replacement, Disconnect the screen: Schritt 12, Bild 3 von 3
    • Use the point of your spudger to push on alternating sides of the left screen connector, just under the right fan, to "walk" it out of its socket.
  13. Razer Blade 15" (2019) Right Fan Replacement, Free the screen cable: Schritt 13, Bild 1 von 2 Razer Blade 15" (2019) Right Fan Replacement, Free the screen cable: Schritt 13, Bild 2 von 2
    • Guide the left screen cable out from the tabs on the right fan.
  14. Razer Blade 15" (2019) Right Fan Replacement, Peel up the fan tape: Schritt 14, Bild 1 von 2 Razer Blade 15" (2019) Right Fan Replacement, Peel up the fan tape: Schritt 14, Bild 2 von 2
    • Use tweezers or your fingers to peel the top right corner of the fan tape from the heatsink.
  15. Razer Blade 15" (2019) Right Fan Replacement, Unfasten the right fan: Schritt 15, Bild 1 von 1
    • Use a Phillips screwdriver to remove the two 6.7 mm screws securing the right fan.
  16. Razer Blade 15" (2019) Right Fan Replacement, Remove the right fan: Schritt 16, Bild 1 von 2 Razer Blade 15" (2019) Right Fan Replacement, Remove the right fan: Schritt 16, Bild 2 von 2
    • Remove the right fan.
Abschluss
Clay Eickemeyer
81.916 Reputation
455 Anleitungen geschrieben
Guide Team Mitglied von Guide Team
Staff
9 Mitglieder
11.426 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 40
Insgesamt: 1,303
