Zum Hauptinhalt wechseln
RetroMini Miyoo Mini Plus Screen Replacement
Was du brauchst
  1. RetroMini Miyoo Mini Plus Screen Replacement, Battery: Schritt 1, Bild 1 von 2 RetroMini Miyoo Mini Plus Screen Replacement, Battery: Schritt 1, Bild 2 von 2
    • Lay the device face down on a flat surface.
    • You may want to lay the device on a towel or other soft surface to avoid scratching the screen.
    Frag FixBot
    Kommentar hinzufügen
  2. RetroMini Miyoo Mini Plus Screen Replacement: Schritt 2, Bild 1 von 2 RetroMini Miyoo Mini Plus Screen Replacement: Schritt 2, Bild 2 von 2
    • Use your fingernail to push in the battery compartment tab.
    • Lift the cover up to expose the battery.
    Frag FixBot
  3. RetroMini Miyoo Mini Plus Screen Replacement: Schritt 3, Bild 1 von 1
    • Use an opening tool to gently lift the the battery from its compartment.
    • Gently pull the battery out and set the battery next to the system, with care not to strain the attached wire.
    Frag FixBot
  4. RetroMini Miyoo Mini Plus Screen Replacement: Schritt 4, Bild 1 von 2 RetroMini Miyoo Mini Plus Screen Replacement: Schritt 4, Bild 2 von 2
    • Pinch the white battery connector and pull it directly out of its socket.
    • Completely remove the battery.
    Frag FixBot
  5. RetroMini Miyoo Mini Plus Screen Replacement: Schritt 5, Bild 1 von 2 RetroMini Miyoo Mini Plus Screen Replacement: Schritt 5, Bild 2 von 2
    • When you have the new battery, put the new battery wire into the connecter.
    • Place the battery back into the empty space with the wire at the bottom of the battery.
    Frag FixBot
  6. RetroMini Miyoo Mini Plus Screen Replacement, Button: Schritt 6, Bild 1 von 2 RetroMini Miyoo Mini Plus Screen Replacement, Button: Schritt 6, Bild 2 von 2
    • Remove the four screws securing the rear case with a Phillips screwdriver.
    • Remove the two Phillips screws inside the battery compartment.
    Frag FixBot
  7. RetroMini Miyoo Mini Plus Screen Replacement: Schritt 7, Bild 1 von 2 RetroMini Miyoo Mini Plus Screen Replacement: Schritt 7, Bild 2 von 2
    • Insert an opening tool into the seam between the front and rear case.
    • Pry the front and rear case apart.
    Frag FixBot
  8. RetroMini Miyoo Mini Plus Screen Replacement: Schritt 8, Bild 1 von 2 RetroMini Miyoo Mini Plus Screen Replacement: Schritt 8, Bild 2 von 2
    • Gently set the rear case aside.
    • Make sure you lift the black tab on the left side of the motherboard and gently remove the ribbon cable as to not damage it when removing the motherboard from the case.
    Frag FixBot
  9. RetroMini Miyoo Mini Plus Screen Replacement: Schritt 9, Bild 1 von 2 RetroMini Miyoo Mini Plus Screen Replacement: Schritt 9, Bild 2 von 2
    • Use an opening tool to lift the motherboard from the chassis.
    Frag FixBot
  10. RetroMini Miyoo Mini Plus Screen Replacement: Schritt 10, Bild 1 von 3 RetroMini Miyoo Mini Plus Screen Replacement: Schritt 10, Bild 2 von 3 RetroMini Miyoo Mini Plus Screen Replacement: Schritt 10, Bild 3 von 3
    • Gently set the motherboard to the side.
    • Remove the rubber button gasket.
    Frag FixBot
  11. RetroMini Miyoo Mini Plus Screen Replacement: Schritt 11, Bild 1 von 1
    • Remove the button(s) you want to replace.
    Frag FixBot
  12. RetroMini Miyoo Mini Plus Screen Replacement, Screen: Schritt 12, Bild 1 von 1
    • Heat an iOpener according to the instructions here.
    • Rest the iOpener Gel Bag on the screen for a minute.
    • Alternatively, use a hair dryer to gently heat the screen to loosen the adhesive that secures it.
    Frag FixBot
  13. RetroMini Miyoo Mini Plus Screen Replacement: Schritt 13, Bild 1 von 2 RetroMini Miyoo Mini Plus Screen Replacement: Schritt 13, Bild 2 von 2
    • Gently apply pressure to the highlighted area on the front cover of the device.
    • While applying the pressure gently peel the screen off of the device.
    • Take care not to flex the screen. If the screen feels stubborn, apply more heat.
    Frag FixBot
  14. RetroMini Miyoo Mini Plus Screen Replacement: Schritt 14, Bild 1 von 3 RetroMini Miyoo Mini Plus Screen Replacement: Schritt 14, Bild 2 von 3 RetroMini Miyoo Mini Plus Screen Replacement: Schritt 14, Bild 3 von 3
    • Set the new screen gently into the ridges (boxed in red) on the front of the backlit screen
    Frag FixBot
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting.
2 weitere Personen haben diese Anleitung absolviert.
Kaden
599 Reputation
4 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 9
Letzte 7 Tage: 52
Letzte 30 Tage: 183
Insgesamt: 2,491
