Einleitung
Use this guide to replace a broken phone connector cable on your Rotor Riot controller.
Was du brauchst
Use your fingers to remove the screw on the back side of the controller securing the iPhone mount.
Remove the iPhone mount.
Use a T6 Torx screwdriver to remove the eight 9.2 mm-long screws securing the back cover.
Lift up the back cover of the controller.
Lift the back cover to a 45 degree angle and place it next to the controller.
Use a spudger to disconnect the phone connector cable from the mainboard.
Pull the screw thread bracket straight up to slide it off of the rails securing it to the back cover.
Repair didn’t go as planned? Ask our Answers community for help.
