Einleitung
Use this guide to replace a worn-out or dead battery in your Samsung Galaxy Watch Active.
If your battery is swollen, take appropriate precautions. For your safety, discharge your battery below 25% before disassembling your watch. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
You might need replacement adhesive to reattach the battery when reassembling the device.
Was du brauchst
Turn off the Galaxy Watch Active by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
When the "Power off" symbol appears tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
Use an opening tool and place it between the plastic back cover and the metal housing near the buttons.
Push the tip of the opening tool into the gap to separate the back cover from the housing.
Carefully lift the back cover approximately 2 cm to access the sensor array connector near the two buttons.
Use a spudger to disconnect the sensor array from the motherboard.
Use the flat end of a spudger to disconnect the display assembly, the microphone and pressure sensor array, and side button.
Use an opening pick to peel back the thin tape belonging to the microphone array.
Use a Phillips screwdriver to remove the 4.4 mm-long screw holding the motherboard in place.
Use an opening pick to loosen the motherboard from the core assembly.
Slide the motherboard out from under the plastic tab to remove it.
Insert the flat end of a spudger between the bottom of the battery and the core frame.
Use the spudger to lever up the battery.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. Press the new battery firmly into place.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 1 more hour. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
16 weitere Personen haben diese Anleitung absolviert.
