Zum Hauptinhalt wechseln
Toshiba Satellite L55-A Battery Replacement
Was du brauchst
  1. Toshiba Satellite L55-A Battery Replacement, Remove the RAM cover: Schritt 1, Bild 1 von 1
    • Before you begin, be sure to power down your laptop.
    • Flip the laptop over so that the back cover is facing up.
    • Unscrew the captive Phillips screw securing the RAM cover.
  2. Toshiba Satellite L55-A Battery Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite L55-A Battery Replacement: Schritt 2, Bild 2 von 2
    • Lift up the edge of the RAM cover and remove it.
  3. Toshiba Satellite L55-A Battery Replacement, Disconnect the ethernet connector cable: Schritt 3, Bild 1 von 3 Toshiba Satellite L55-A Battery Replacement, Disconnect the ethernet connector cable: Schritt 3, Bild 2 von 3 Toshiba Satellite L55-A Battery Replacement, Disconnect the ethernet connector cable: Schritt 3, Bild 3 von 3
    • Use an opening tool to pry up the ethernet connector cable from its socket near the RAM module.
    • Disconnect the cable.
    • During reassembly, make sure you re-insert this connector right-side-up. The connector is keyed to plug in only one orientation, so if it doesn't slide into place easily, turn it around and try the other way.
  4. Toshiba Satellite L55-A Battery Replacement, Remove the back cover: Schritt 4, Bild 1 von 1
    • Remove the thirteen 6.8 mm long Phillips screws securing the back cover.
  5. Toshiba Satellite L55-A Battery Replacement: Schritt 5, Bild 1 von 3 Toshiba Satellite L55-A Battery Replacement: Schritt 5, Bild 2 von 3 Toshiba Satellite L55-A Battery Replacement: Schritt 5, Bild 3 von 3
    • Insert the point of an opening pick in the seam between the SuperMultiDrive and the rest of the back cover.
    • Push the SuperMultiDrive's lip away from the back cover to disconnect the drive.
    • Slide the drive out of the bay and remove it from the laptop.
  6. Toshiba Satellite L55-A Battery Replacement: Schritt 6, Bild 1 von 2 Toshiba Satellite L55-A Battery Replacement: Schritt 6, Bild 2 von 2
    • The back cover is still held in place by plastic clips.
    • Insert the point of an opening pick into the back cover seam near the ethernet port.
    • Twist the pick to release the plastic clips along the edge.
  7. Toshiba Satellite L55-A Battery Replacement: Schritt 7, Bild 1 von 3 Toshiba Satellite L55-A Battery Replacement: Schritt 7, Bild 2 von 3 Toshiba Satellite L55-A Battery Replacement: Schritt 7, Bild 3 von 3
    • Grasp the loosened back case edge with your hand and lift it slowly away from the laptop. The remaining clips should release with ease.
    • If you meet significant resistance, stop and check for forgotten screws.
    • Remove the back cover.
    • To reinstall the back cover, align the cover and press along the edges to snap the clips back in place.
  8. Toshiba Satellite L55-A Battery Replacement, Unscrew the battery: Schritt 8, Bild 1 von 1
    • Remove the two 6.8 mm long Phillips screws securing the battery.
  9. Toshiba Satellite L55-A Battery Replacement: Schritt 9, Bild 1 von 2 Toshiba Satellite L55-A Battery Replacement: Schritt 9, Bild 2 von 2
    • Lift the battery out of its recess and move it slightly away from the motherboard in order to reveal the battery cable.
  10. Toshiba Satellite L55-A Battery Replacement, Disconnect the battery: Schritt 10, Bild 1 von 2 Toshiba Satellite L55-A Battery Replacement, Disconnect the battery: Schritt 10, Bild 2 von 2
    • Grasp the battery cable near its motherboard socket and pull the connector horizontally out of the socket.
  11. Toshiba Satellite L55-A Battery Replacement, Remove the battery: Schritt 11, Bild 1 von 1
    • Remove the battery.
Abschluss
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Arthur Shi
253.292 Reputation
526 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
135 Mitglieder
17.147 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 29
Insgesamt: 1,608
