Zum Hauptinhalt wechseln
iPad 5 Wi-Fi Rear Facing Camera Replacement
Was du brauchst
  1. iPad 5 Wi-Fi Rear Facing Camera Replacement, Heat the left edge: Schritt 1, Bild 1 von 1
    • Heat an iOpener and apply it to the left edge of the device for two minutes.
  2. iPad 5 Wi-Fi Rear Facing Camera Replacement, Screen removal information: Schritt 2, Bild 1 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement, Screen removal information: Schritt 2, Bild 2 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement, Screen removal information: Schritt 2, Bild 3 von 3
    • While you're waiting for the adhesive to loosen, note the following areas that are sensitive to prying:
    • Front camera
    • Antennas
    • Display cables
  3. iPad 5 Wi-Fi Rear Facing Camera Replacement, Anti-Clamp instructions: Schritt 3, Bild 1 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement, Anti-Clamp instructions: Schritt 3, Bild 2 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement, Anti-Clamp instructions: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place an object under your iPad so it rests level between the suction cups.
    • Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  4. iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 4, Bild 1 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 4, Bild 2 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 4, Bild 3 von 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 5, Bild 1 von 2 iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 5, Bild 2 von 2
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the digitizer when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
  6. iPad 5 Wi-Fi Rear Facing Camera Replacement, Insert an opening pick: Schritt 6, Bild 1 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement, Insert an opening pick: Schritt 6, Bild 2 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement, Insert an opening pick: Schritt 6, Bild 3 von 3
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Once the screen is warm to touch, apply a suction handle to the left edge of the screen and as close to the edge as possible.
    • Lift the screen with the suction handle to create a small gap between the digitizer and the frame.
    • Insert an opening pick into the gap between the digitizer and the frame.
  7. iPad 5 Wi-Fi Rear Facing Camera Replacement, Separate the left adhesive: Schritt 7, Bild 1 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement, Separate the left adhesive: Schritt 7, Bild 2 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement, Separate the left adhesive: Schritt 7, Bild 3 von 3
    • Insert a second opening pick into the gap you just created.
    • Slide the pick toward the bottom-left corner of the device to separate the adhesive.
    • Leave the pick in the bottom-left corner to prevent the adhesive from re-sealing.
    • Don't worry if you can see the opening pick through the digitizer—just pull the pick out. The LCD screen shouldn't be damaged, but you risk leaving behind hard-to-clean adhesive.
  8. iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 8, Bild 1 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 8, Bild 2 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 8, Bild 3 von 3
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad to continue separating the adhesive.
  9. iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 9, Bild 1 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 9, Bild 2 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 9, Bild 3 von 3
    • Slide the first opening pick towards the top-left corner of the device to separate the adhesive.
    • Leave the pick in the top-left corner to prevent the adhesive from re-sealing.
  10. iPad 5 Wi-Fi Rear Facing Camera Replacement, Heat the top edge: Schritt 10, Bild 1 von 1
    • Heat an iOpener and apply it to the top edge of the device for two minutes.
  11. iPad 5 Wi-Fi Rear Facing Camera Replacement, Separate the top left adhesive: Schritt 11, Bild 1 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement, Separate the top left adhesive: Schritt 11, Bild 2 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement, Separate the top left adhesive: Schritt 11, Bild 3 von 3
    • Rotate the pick around the top-left corner of the device to separate the adhesive.
  12. iPad 5 Wi-Fi Rear Facing Camera Replacement, Separate the top adhesive: Schritt 12, Bild 1 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement, Separate the top adhesive: Schritt 12, Bild 2 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement, Separate the top adhesive: Schritt 12, Bild 3 von 3
    • Slide the opening pick along the top edge of the device, stopping just before you reach the front camera.
    • Avoid sliding the pick over the front camera, as you may damage the lens. The following steps will show how to prevent this.
  13. iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 13, Bild 1 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 13, Bild 2 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 13, Bild 3 von 3
    • Pull the pick out until only the tip is between the digitizer and the frame.
    • Slide the pick above the front camera to separate the adhesive.
    • Leave the pick near the right side of the front camera before continuing.
  14. iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 14, Bild 1 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 14, Bild 2 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 14, Bild 3 von 3
    • Re-insert the pick and slide it towards the top-right corner of the device to completely separate the top adhesive.
    • Leave the pick in the top-right corner to prevent the adhesive from re-sealing.
  15. iPad 5 Wi-Fi Rear Facing Camera Replacement, Heat the right edge: Schritt 15, Bild 1 von 1
    • Heat an iOpener and apply it to the right edge of the device for two minutes.
  16. iPad 5 Wi-Fi Rear Facing Camera Replacement, Separate the top right adhesive: Schritt 16, Bild 1 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement, Separate the top right adhesive: Schritt 16, Bild 2 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement, Separate the top right adhesive: Schritt 16, Bild 3 von 3
    • Rotate the pick around the top-right corner of the device to separate the adhesive.
  17. iPad 5 Wi-Fi Rear Facing Camera Replacement, Separate the right adhesive: Schritt 17, Bild 1 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement, Separate the right adhesive: Schritt 17, Bild 2 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement, Separate the right adhesive: Schritt 17, Bild 3 von 3
    • Insert a new opening pick and slide it to the middle of the iPad's right edge.
    • The display cables are located approximately halfway from the bottom of the iPad. Stop sliding once you reach three inches from the bottom of the iPad.
  18. iPad 5 Wi-Fi Rear Facing Camera Replacement, Heat the bottom edge: Schritt 18, Bild 1 von 1
    • Heat an iOpener and apply it to the bottom edge of the device for two minutes.
  19. iPad 5 Wi-Fi Rear Facing Camera Replacement, Separate the bottom left adhesive: Schritt 19, Bild 1 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement, Separate the bottom left adhesive: Schritt 19, Bild 2 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement, Separate the bottom left adhesive: Schritt 19, Bild 3 von 3
    • Slide the bottom-left pick to the bottom-left corner to separate the adhesive.
    • Don't fully rotate the pick around the corner, as you may damage the antenna.
    • Leave the pick in the bottom-left corner before moving to the next step.
  20. iPad 5 Wi-Fi Rear Facing Camera Replacement, Separate the bottom adhesive: Schritt 20, Bild 1 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement, Separate the bottom adhesive: Schritt 20, Bild 2 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement, Separate the bottom adhesive: Schritt 20, Bild 3 von 3
    • Insert a new opening pick into the gap you just created on the bottom edge of the iPad.
    • Slide the pick over the antenna, stopping just before the home button.
    • Only slide the pick towards the home button and not away from it, as you may damage the antenna.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-left corner.
    • Leave the pick to the left of the home button before continuing.
  21. iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 21, Bild 1 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 21, Bild 2 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 21, Bild 3 von 3
    • Insert an opening pick into the gap you just created.
    • Slide the pick underneath the home button and towards the bottom-right corner, making sure only the tip is between the digitizer and the frame.
    • Only insert the pick up to 1 mm to avoid damaging the right antenna.
  22. iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 22, Bild 1 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 22, Bild 2 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 22, Bild 3 von 3
    • Re-insert the pick and slide it towards the home button to completely separate the bottom adhesive.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-right corner.
    • Leave the pick to the right of the home button before continuing.
  23. iPad 5 Wi-Fi Rear Facing Camera Replacement, Heat the right edge: Schritt 23, Bild 1 von 1
  24. iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 24, Bild 1 von 2 iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 24, Bild 2 von 2
    • Be very careful with this step. Take your time, ensure the adhesive is hot and soft, and make sure you separated all of the adhesive with a pick. Don't be afraid to stop and reheat.
    • Twist the two opening picks on the left corners of the iPad to lift the digitizer slightly, separating the the last of the adhesive in the process.
    • If there's a significant amount of resistance, reheat the edges and work along them with an opening pick.
  25. iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 25, Bild 1 von 2 iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 25, Bild 2 von 2
    • Lift the left edge of the digitizer upwards to further separate the adhesive along the right edge of the iPad.
  26. iPad 5 Wi-Fi Rear Facing Camera Replacement, Separate the right adhesive: Schritt 26, Bild 1 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement, Separate the right adhesive: Schritt 26, Bild 2 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement, Separate the right adhesive: Schritt 26, Bild 3 von 3
    • While supporting the digitizer, slide an opening pick between the two display cables to separate the last of the adhesive.
  27. iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 27, Bild 1 von 2 iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 27, Bild 2 von 2
    • Once all of the adhesive has been separated, open the digitizer like a book and rest it parallel to the iPad.
    • During reassembly, clean the remaining adhesive from the frame—and the digitizer if you're re-using it—with isopropyl alcohol. Replace the adhesive with our adhesive strips or pre-cut adhesive cards.
    • Be mindful of the display cables when reassembling the device. Make sure they are folded properly underneath the LCD screen to prevent any damage.
  28. iPad 5 Wi-Fi Rear Facing Camera Replacement, LCD: Schritt 28, Bild 1 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement, LCD: Schritt 28, Bild 2 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement, LCD: Schritt 28, Bild 3 von 3
    • Remove any tape obscuring the LCD screws.
  29. iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 29, Bild 1 von 1
    • Remove the following Phillips screws securing the LCD.
    • Three 4.0 mm screws
    • One 4.8 mm screw
  30. iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 30, Bild 1 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 30, Bild 2 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 30, Bild 3 von 3
    • Do not attempt to fully remove the LCD. It is still connected to the iPad by several cables at the home button end. Lift only from the front-facing camera end.
    • Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers.
    • Flip the iPad LCD like a page in a book, lifting near the camera and turning it over the home button end of the rear case.
    • Be gentle and keep an eye on the LCD cables as you flip the display over.
    • Lay the LCD on its face to allow access to the display cables.
    • Set the LCD down on a soft, clean, lint-free surface.
  31. iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 31, Bild 1 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 31, Bild 2 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 31, Bild 3 von 3
    Battery Blocker
    $3.99
    • Remove the single 2.3 mm Phillips screw securing the battery connector to the logic board.
    • To reduce the risk of a short, you can insert a battery blocker or a modified opening pick to disconnect the battery.
    • Be very careful when you isolate the battery using a battery blocker. The battery contacts are easily damaged, resulting in irreversible damage.
    • Slide the battery blocker underneath the battery connector area of the logic board, and leave it in place while you work.
    • If you are having trouble fitting the battery blocker underneath the logic board, you can try using a playing card to disconnect the battery.
  32. iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 32, Bild 1 von 1
    • Remove the three 1.4 mm Phillips screws from the display cable bracket.
  33. iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 33, Bild 1 von 2 iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 33, Bild 2 von 2
    • Use the flat end of a spudger to gently pry the display cable bracket straight up from the logic board.
    • The display cable connector is adhered to the underside of the bracket, so don’t push the spudger too far under the bracket, or you may damage the connector.
  34. iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 34, Bild 1 von 1
    • Remove the LCD.
  35. iPad 5 Wi-Fi Rear Facing Camera Replacement, Front Panel Assembly: Schritt 35, Bild 1 von 2 iPad 5 Wi-Fi Rear Facing Camera Replacement, Front Panel Assembly: Schritt 35, Bild 2 von 2
    • Remove any tape covering the home button ribbon cable connector.
  36. iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 36, Bild 1 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 36, Bild 2 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 36, Bild 3 von 3
    • Use the flat end of a spudger to flip the tab on the home button ribbon cable ZIF connector upward.
    • Carefully pull the home button ribbon cable horizontally out of the ZIF connector.
  37. iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 37, Bild 1 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 37, Bild 2 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 37, Bild 3 von 3
    • Use a the flat end of a spudger or a fingernail to carefully pop the two digitizer cable connectors straight up from their sockets.
    • To avoid damaging your iPad, pry only on the connectors themselves, not on the socket on the logic board.
  38. iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 38, Bild 1 von 2 iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 38, Bild 2 von 2
    • Carefully peel the home button ribbon cable up off of the adhesive holding it to the rear case.
  39. iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 39, Bild 1 von 2 iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 39, Bild 2 von 2
    Polyimide Tape
    $9.99
    • Remove the front panel assembly.
    • During reassembly, wipe any dust or fingerprints off of the inside of the front panel assembly to ensure a clean display.
    • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit panels come with the proper insulation, and should not require the addition of any tape.
    • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
    • The insulation is not visible to the naked eye, and is different from the foam dust barrier strips found on many iPads.
  40. iPad 5 Wi-Fi Rear Facing Camera Replacement, Upper Component Cable Bracket: Schritt 40, Bild 1 von 1
    • Remove the three 1.4 mm Phillips #000 screws securing the upper component cable bracket.
  41. iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 41, Bild 1 von 1
    • Remove the upper component cable bracket.
    • If you have the Wi-Fi/Cellular model, your iPad will look slightly different and will require the removal of two additional screws to access components covered by this bracket.
  42. iPad 5 Wi-Fi Rear Facing Camera Replacement, Rear Facing Camera: Schritt 42, Bild 1 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement, Rear Facing Camera: Schritt 42, Bild 2 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement, Rear Facing Camera: Schritt 42, Bild 3 von 3
    • Use the flat end of a spudger to disconnect the rear-facing camera connector from the logic board.
    • Only pry up on the connector—not on the socket itself.
    • Push the rear-facing camera cable to the left to clear it out of the way.
  43. iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 43, Bild 1 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 43, Bild 2 von 3 iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 43, Bild 3 von 3
    • Slide a plastic opening tool under the rear facing camera and pry upward to free it from the adhesive securing it to the rear case.
  44. iPad 5 Wi-Fi Rear Facing Camera Replacement: Schritt 44, Bild 1 von 1
    • Remove the rear-facing camera.
Abschluss
Evan Noronha
228.839 Reputation
168 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 37
Insgesamt: 2,249
