Einleitung
Use this guide to replace the home button assembly in your iPhone 5s.
Please note that only the phone's original home button assembly will be capable of using the Touch ID functionality. Installing a new home button will only restore ordinary home button functions, not the Touch ID features.
You can also use this guide to replace the following parts:
Was du brauchst
Einführungsvideo
Power off your iPhone before beginning disassembly.
Remove the two 3.9 mm Pentalobe screws from either side of Lightning connector.
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
Regardless of the tool you use, you need to be sure you pull up the entire display.
If the glass begins to separate from the plastic, as shown in the first image, slide a plastic opening tool between the plastic frame and the metal phone body to pry the metal clips out of the case.
In diesem Schritt verwendetes Werkzeug:Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Pull the blue handle forwards to lock the arms.
Turn the handle clockwise 360 degrees or until the cups start to stretch.
Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
Skip the next two steps.
If you don't have an Anti-Clamp, use a single suction cup to lift the front panel:
Press a suction cup onto the screen, just above the home button.
While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the home button end of the front panel from the rear case.
With a plastic opening tool, gently pry the edges of the rear case down, away from the front panel assembly, while you pull up with the suction cup.
Pull the plastic nub to release the vacuum seal on the suction cup.
Remove the suction cup from the screen.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Open the phone just enough to reveal the metal bracket covering the home button cable.
Only the phone's original home button assembly will be capable of using the Touch ID functionality. If you rip the cable, installing a new home button will only restore ordinary home button functions, not the Touch ID features.
Use the tip of a spudger to push the bracket free and remove it with tweezers.
Use the tip of a spudger to pry the home button cable connector up out of its socket.
Once the connector has been released, pull the home button end of the assembly away from the rear case, using the top of the phone as a hinge.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
Remove the two 1.6 mm Phillips #000 screws securing the metal battery connector bracket to the logic board.
Use the flat end of a spudger to gently pry the battery connector up from its socket on the logic board.
Remove the following screws securing the front panel assembly cable bracket to the logic board:
One 1.7 mm Phillips #000 screw
One 1.2 mm Phillips #000 screw
One 1.3 mm Phillips #000 screw
One more 1.7 mm Phillips #000 screw
Use a spudger or a fingernail to disconnect the front-facing camera and sensor cable.
Unscrew the single captive Phillips #000 screw securing the home button cable.
Wedge the the tip of a spudger underneath the home button cable assembly.
Gently work the spudger underneath the cable to separate the home button cable from the front panel assembly.
Gently push the top left corner of the home button up away from the front panel.
Peel the home button the rest of the way off of the display by prying gently with a spudger.
326 weitere Nutzer:innen haben diese Anleitung absolviert.
39 Kommentare
Has anyone attempted to replace the metal ring around the finger scanner?
I was unable to find any info on this, I'd like to offer this as a custom service, I'd be great to get some guidance without wrecking a few of em first.
If you’ve got a iPhone 5S with a broken touch ID button or flex cable, you’re pretty much stuck! The iPhone 5S touch ID and motherboard are linked specifically to each other and there is no way to swap out the touch ID and still have the fingerprint sensors work.
Don’t ever attempt to change the iPhone 5S home button from the flex cable. The sensor is glued to the sapphire with very strong adhesive. Disassembling the button from the chip will cause irreversible damage. The electronic components will be different if you attempt to connect another button to the touch ID flex and will not function. You can’t recalibrate the sensor and it will never read fingerprints again. It will however function as a home button.
ben -
Steps 11-16 are not really needed. Just replaced the home button on an iPhone 5s and there is no need to fully detach the front from the back of the phone. After step 10 just prop the phone open so that the button can be removed. Replace button. Reconnect cable and then then close the phone up. Otherwise a really a good guide.
So you don't need to remove the home button ribbon cable?
brian -
if the fingerprint touch id cable is damaged..the cable only can be repaired?
