Zum Hauptinhalt wechseln
Reparaturanleitungen, Bedienungsanleitungen und Informationen zur Fehlersuche beim FixHub Power Series | Intelligenten Lötkolben. Erhältlich seit Mitte Oktober 2024.
Soldering iron tip storage
Is there a storage solution for the different/extra tips for fixhub soldering iron?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
3 Kommentare
I would also like a storage case for the extra tips. Currently I am using the Zipper pouch that I got with Electronics Cleaning Bundle. But the extra tips are still in the "retail" packaging to prevent any damage to them. I would like something like a "chef's knifes rolling case" for them
Certa Cito
von
i have a basic tip storage that holds 3 tips i can share if you can find someone to print it for you? it just sits on top of the battery
von
@econut Thanks for the offer!
That would be great :-)
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
@leeperry67874 , we're working on something like this. In the meantime, maybe you might consider making a 3D printed option?
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Unfortunately I don't own a 3d printer, but does a Hakko B2756 Soldering Tip Holder/stand work or is compatible with the FixHub Soldering Iron Tips for storage? or fit in the ifixit Zipper Pouch?
von
@leeperry6376, I totally understand. You might also want to check with your local library to see if they have a Maker Space. Some libraries offer these spaces equipped with 3D printers, which could be helpful. It’s worth looking into.
As for the compatibility of the Hakko Soldering Tip Holder with the FixHub tips, I can’t say for sure. They might fit in the pouch, but that will likely depend on your preference and setup.
von
Antwort hinzufügen
Lee Perry wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 39
Insgesamt: 547
