Where is the accelerometer located
The accelerometer stopped working.
Ist dies eine gute Frage?
Brett Turner, U205 on the image is the accelerometer.
Hope this helps, good luck.
Abnormal Acceleration,Gyro Sensor part
Check the Voltage
C238 = 2.8V
C239 = 2.8V
C237 = 1.8V
If No then Resolder U205 or REflow U500
If Yes
Check the Voltage
R460 = 1.8V
R461 = 1.8V
If No Resolder U500 or Reflow UCP400
If Yes
Acceleration,Gyro Sensor operate correctly?
If No REflow or Replace U205 using a Heatgun or change Logic board.
The resistors and capacitors are marked on the second image, including the schematic of where to measure. Again, hope this helps.
War diese Antwort hilfreich?
Thank you. Now I'm thinking it's a software issue because it looks fine. ofcourse I can't see inside it.
Do you have a multimeter? There are a few things you can check. It's a bit tricky but not impossible. You will also have to know how to read a schematic.
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 10
Insgesamt: 4,862
2 Kommentare
are you sure its not a setting's issue ?
von ifixshop
Yes I'm sure.
von Brett Turner
