Zum Hauptinhalt wechseln
13" Aluminium Unibody, 2,0 oder 2,4 GHz Core 2 Duo Prozessor.
574 Fragen Alle anzeigen
How to repair faulty earphone jack
How do i get at the earphone jack to replace or repair it
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
1 Kommentar
thanks for the info Gabe Chai/nicksmacan,i guessed it would be messy,kind of vacate the house,warn
the neighbours, pails of water to hand,send the kids to their grandmas. thanks again.
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
You would need to replace the entire logic board, or as nick said, you would need to do some intense soldering. If I were you, I would get a USB sound card and this would bypass the sound card built in:
http://www.newegg.com/Product/Product.as...
War diese Antwort hilfreich?
Bewertung 3
While you can repair this board and just replace the jack, you're going to need to so some SMD or tight through hole soldering.
Follow this to get the board out and repair the jack: MacBook Unibody Modell A1278 Logic Board tauschen
Bewertung 2
its not intense at all if you have ever done any PCB soldering at all. its easier to replace than a capacitor even, you don't have to worry about bending it this way or that and breaking it off.
Bewertung 0
Antwort hinzufügen
luke walsh wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 4,177
