Zum Hauptinhalt wechseln
Veröffentlicht am 16. Oktober 2014, Modellnummer A1347 - EMC 2840
Adding SSD Drive to PCIe model
Can anyone assist with what parts I would need to add an SSD to a Mac Mini 2014 that came with a PCIe 512 GB drive?
I'd like to make it a dual drive setup, but can't confirm what part is needed to do so. Any help would be greatly appreciated.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
2 Kommentare
me to i would like to recieve and so place a PCIE drive on my mac mini late 2014. can you send me the link for buying that item?
bst regards
von
@yannick17 - Review my answer for the details
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
If you already have the PCIe SSD then you're adding a SATA drive (either a HD or a SSD) You'll need the to follow this IFIXIT guide Mac mini Late 2014 Festplattenkabel tauschen and need this part & tool kit: Mac mini Dual Drive Kit. Be careful here! The size of the drive needs to physically fit (12 mm is about it).
If you have a SATA HD already then you'll want this: either the drive carrier with the SSD cable mounted Hard Drive Carrier w/ SSD Flex Cable - Apple P/N 076-00040 or the cable its self Cable, SSD Flex - Apple P/N 076-00018
Here's the IFIXIT guides:
All the hardware needed to a second hard drive to your 2011 or 2012 Mac mini. Bild
Produkt
$26.99
Mac mini Late 2014 PCIe SSD Kabel Bild
Anleitung
Mac mini Late 2014 PCIe SSD Kabel austauschen
Schwierigkeitsgrad:
Mittel
15 - 20 minutes
Mac mini Late 2014 Festplattenkabel Bild
Anleitung
Schwierigkeitsgrad:
Mittel
1 hour
Mac mini Late 2014 Laufwerkseinschub Bild
Anleitung
Mac mini Late 2014 Laufwerkseinschub austauschen
Schwierigkeitsgrad:
Mittel
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Dan, If I already have a fusion drive in there will I need any of these replacement parts, or can I just substitute the respective PCIe and 2.5 inch drives for the existing ones?
von
You'll need to make a full backup before doing anything.
First step is to break the Fusion Drive following this How to split up a Fusion Drive.
And yes, all of the needed hardware sans the replacement drive/s is present.
But before you jump what is your goals here?
von
When adding a HDD to a PCIe SSD only 2014 mini, which HDD cable do you need? (1) the mini dual drive cable, or (2) the upper SATA cable?
Bewertung 0
Antwort hinzufügen
tomtcs wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 10
Letzte 30 Tage: 34
Insgesamt: 1,891
