Zum Hauptinhalt wechseln
Veröffentlicht am 16. September 2016. Modelbezeichnung 1660, 1778. Verfügbar in den Versionen: GSM oder CDMA / 32, 128 oder 256GB / Rosé Gold, Gold, Silber, Mattschwarz oder Hochglanz-Schwarz
2265 Fragen Alle anzeigen
Will alcohol affect the Taptic-Engine?
I went to the beach and have salt water damage. I read alcohol was good to use but all the videos were on iPhone 6's and below so can I keep in the taptic-engine or take it out before I put it in rubbing alcohol?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Avoid rubbing alcohol (it has all other kinds of chemicals that harm the logic board), use pure alcohol like isopropyl alcohol 90% or higher is best.
von
The taptic-engine is similar to a door bell an electromagnet moves a piston within to then strike the chime. Here its just a mass that is moved to give you the feeling of movement.
So yes any liquid that gets into it will damage it. So I won't immerse it just wipe it down.
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
I would remove it just to be safe.
Electronics Water Damage
There is a great guide on how to do it properly.
iPhone 7 Teardown
There is how to teardown your iphone
War diese Antwort hilfreich?
Bewertung 4
You need to disassemble the total phone. You can´t lay the complete phone in isopropanol. This will definitely kill the speakers and both cameras (residual on sensor). Only clean the logic board. If there are any errors caused by flex cable parts, replace them do not clean them this won´t work for long therm.
Bewertung 2
Antwort hinzufügen
Hynia Morris wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 344
