Zum Hauptinhalt wechseln
The ASUS ZenPad 3S 10 is a 9.7-inch tablet in the ZenPad line released by ASUS in October 2015. Model: P027.
20 Fragen Alle anzeigen
Replacing my Charger/cable with proper selection
Hello, I lost/destroyed the cable and wall charger for my zenpad and wanted to replace them, but I have heard of some issues with the wrong c-types causing issues.
I picked up a JW ( just wireless) home charger with dual usb to usb type-c kit
its rated at 17Watt/3.4 amp w a 3.0 quickcharge . Anyone know if this would be safe to use with the zenpad 3s 10? and if not can you point me towards what i should be seeking? thank you in advance.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Here's a useful reference, though a long thread. It mentions 18 watts to quickcharge, but I would think that 17 is close enough. They also mention using a phone charger that can do quickcharge. I looked into it and found this PDF of certified accessories (will download when clicked): https://www.qualcomm.com/media/documents...
Seems useful for reference.
This is the closest I could find to the specs for the/an Asus original charger. It is quickcharge 3.0, and if the one you have doesn't work out, this one uses (5v) USB so you could probably use it in your house just as well.
Good luck!
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Mike wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 705
