Zum Hauptinhalt wechseln
An E-reader released by Amazon.com on April 27th 2016. The model number is SW56RW.
18 Fragen Alle anzeigen
My Kindle Oasis fell into the water. Can you repair it?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
@goodharbor122 we can't fix it for you. We are volunteers that help others to fix their own devices. In the case of your Kindle, I recommend that you totally disassemble it using these guides Amazon Kindle Oasis 8th Gen Motherboard Replacement Then clean every part with some 90%+ isopropyl alcohol. That includes the cables, connectors etc. Use something like this guide iPhone Wasserschaden reparieren to see how to clean a device. The guide was written for an iPhone but the same pretty much applies to any device. After you clean it and have it dried, replace the battery and then reassemble. Only then can you evaluate your Kindle for any other damage.
iPhone Bild
Anleitung
Schwierigkeitsgrad:
Schwierig
1 - 2 hours
Amazon Kindle Oasis (8th Gen) Motherboard Bild
Anleitung
Schwierigkeitsgrad:
Schwierig
20 minutes
War diese Antwort hilfreich?
Bewertung 4
you will need to take it to a local repair shop as this site is to help people, not for repair service
Bewertung 2
Antwort hinzufügen
Loretta Ligor wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 8
Insgesamt: 585
