Zum Hauptinhalt wechseln
Can I operate MBP with case disassembled?
Hello everyone. My Superdrive will not eject DVD. I have preformed every published remedy, including "drutil eject +sudo...". I have begun to disassemble the case and I have two questions:
1) Can I operate the MBP while the machine is disassembled in order to test the superdrive
2) Is there a method for keeping the keyboard out of the way while removing the superdrive, without removing the ribbon? ( see step 9 in Guide)
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Is there a disk in the drive?
von
Yes, at least one. Hard stuck.
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
First thing to do is get the drive out open it up and take the disk out.
There not a lot of “testing” to be done here. This is a very common failure on a machine this old and replacement drives are cheap. When I say cheap I’m not talking about iFixit prices on this (which are not cheap).
MacBook Pro (15 Zoll, Core 2 Duo, Modelle A1226 und A1260) optisches Laufwerk tauschen
War diese Antwort hilfreich?
Bewertung 1
You can keep the casing open. I recommend to use something to prop the keyboard open so you can work and use the keyboard if needed
Bewertung 0
3 Kommentare:
Thank you for responding chickendude. Just to be clear, with case propped open I can power-up the MBP in order to test the superdrive?
von
Yes, as long as all of the components are attached the computer will continue to function. The casing does not affect the operation of the device.
von
What Michael said
von
Antwort hinzufügen
SD Stone wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 85
