Zum Hauptinhalt wechseln
Herausgegeben am 25. September 2015. Model A1687/A1634. Die Reparatur des 6s gestaltet sich ähnlich zu denen früherer Generationen; benötigt werden Schraubenzieher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA / 16, 64 oder 128 GB / Silber, Gold, Space Grau oder Roségold.
Important capacitors missing .?
Hello, i was working on my iphone 6s and i found that this 2 capacitors near 338S1285 audio ic are missing .
(x1072; x1073)
OR
Can that be the problem with the loudspeaker greyed out and no volume bar when volume buttons are pressed? I think one of them connects to the audio chip.
It would be awesome if you can tell me their values!
Thank you!
EDIT: As i can see from the second photo i uploaded, this aren`t capacitors aren`t they?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
As Daniel notes, these are filters, not capacitors. Because of this, their absence would certainly cause issues with any circuit. However, FL3803/FL3804, as indicated, are responsible for the Arc circuit (Taptic Engine). By now, you have probably noticed that both the ARC and Speaker circuit use the same IC (CS35L21). U3800 is the Arc Driver and U3700 is the Speaker Amp.
War diese Antwort hilfreich?
Bewertung 3
no they are filters its probably the audio ic that is the problem
Bewertung 2
Antwort hinzufügen
mangustarooficial wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 276
