Zum Hauptinhalt wechseln
Modell von 2011, A1278 / 2,4 GHz i5 oder 2.8 GHz i7 Prozessor.
591 Fragen Alle anzeigen
How can I clean this?
So, i just cleaned my laptop screen with toner, and after that idk, just found my screen like in this photo, and please help me to escape this. Thanks.
Update (04/02/2019)
Thanks for your respon,
I wipe the screen with cajuput oil, and this mark still there, so what should i do?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
What do you mean you cleaned it with "toner"? Does the affected area feel rough when you lightly glide your fingers across it?
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Sadly I suspect you’ve damaged the LCD cover glass or the LCD panel its self is damaged. You need to be very careful as solvents and oils can damage it.
At this point you’ll need to live with it or replace the display MacBook Pro (13 Zoll, Ende 2011, Unibody) Display austauschen. You might be able to replace the cover glass following this guide MacBook Pro (15 Zoll, Mitte 2009, Unibody, 2,53 GHz) LCD austauschen picking up at Step19 from this guide.
MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Bild
Anleitung
Schwierigkeitsgrad:
Sehr schwierig
MacBook Pro 13" Unibody Late 2011 Display Bild
Anleitung
Schwierigkeitsgrad:
Schwierig
45 minutes - 1 hour
War diese Antwort hilfreich?
Bewertung 3
3 Kommentare:
I'm betting predisposed damage being present and then cleaning it exposed it. I deal with it from time to time on exposed panel notebooks and displays. Usually scratching that was hidden before I cleaned it.
Unless the OP used something harsh on it (plausible since it's not something that's indicative of typical predisposed damage), that's the only possibility.
von
all good! Thank you.
von
From the picture I cant tell if that is on the outside or inside of the glass. If it is outside then use a microfiber cloth and scrub it off. If it is on the inside then it is probably condensation on the inside from the cleaner you used. In that case my advice would be to give it time to dry .
Bewertung 1
Antwort hinzufügen
Dian Fathri Wardana wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 134
