Zum Hauptinhalt wechseln
Reparaturanleitungen, Handbücher und Hilfe bei der Fehlersuche für Apple LED Cinema Display 27". Hier findest du alles, was du für deine Apple LED Cinema Display 27" Reparatur brauchst.
20 Fragen Alle anzeigen
Moving Lines (marching ants)
From left to right I’ve noticed a series of lines roughly spaced 1cm apart across the entire screen. These are not consistent but more like moving pixels that look to be moving from the bottom of the screen to the top, they’re really faint however having noticed them its now something I can’t not see, any ideas? is this a sign of impending death?
IMG_2367.HEIC
IMG_2368.HEIC
Ist dies eine gute Frage?
Bewertung 0
7 Kommentare
Can you take some pics or a short vid and post them here for us to see Bilder zu einer vorhandenen Frage hinzufügen
von
here you go dan :)
von
Sorry I don't see the lines, the vid is a bit blurry which could be hiding it.
Take some stills at the highest resolution and you might want to use a stack of books to help steady the iPhone.
von
struggling to upload images for some reason but looks like this
https://www.youtube.com/watch?v=ozX3RmgM...
von
OK I see the issue!
Let narrow down possible sources of the issue
First do you see this on other external monitors? If you have an iMac do you see it on the iMac's screen as well? What is your system and the video board?
Are you using a surge suppressor which both the system and the display are plugged in?
Have you altered your systems config in any way?
Does this effect come and go?
von
2 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
I’m starting to think the T-CON board on the backside of the LCD panel has an issue. If you can find a panel which is cracked you should be able to salvage the T-CON board from it. The other option is getting a replacement panel. I’ve seen some listed on eBay for around $250 USD often I see them listed around $500 USD.
Heres the part info: Apple LED Cinema Display 27" A1316 LCD Screen Panel LM270WQ1 (SD)(B1) - Apple P/N 661-5542
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
jack crowther wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 458
