Zum Hauptinhalt wechseln
Kam im Juni 2016 auf den Markt, in Europa anhand der Modellnummer A3003 zu identifizieren, in China und Nordamerika mit A3000 (entsprechend https://forums.oneplus.net/threads/oneplus-3-regions-model-numbers.452381/)
66 Fragen Alle anzeigen
Digitizer does not work after screen replacement
I replaced screen and digitizer and it seems everything went fine. The phone turns on but the touch doesn't work, the back and all app button do work. I tried doing a factory reset but it stills doesn't work. What could be the problem?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi Neil,
I would suggest disconnecting and re-seating the display cable. Carefully check the connector for any debris—the pins on the connectors are tiny.
OnePlus 3 Display und Touchscreen tauschen
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Hello Arthur,
I tried disconnecting and re-seating the display cable as you suggested but still nothing. Could it be a motherboard problem or should I send back the display+digitalizer and try with another one?
von
Hey Neil,
It could be a motherboard, though I'd think that the display may have a slightly higher chance of being the problem. Does the original screen work enough to be used as a test? Unfortunately with how the replacement is set up, it's not easy to swap displays.
von
Antwort hinzufügen
Neil Considine wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 7
Insgesamt: 221
