How to fix broken ram slot
One of the two ram slots broke, is there a way to fix it
Ist dies eine gute Frage?
There is. but your not going to like it. but contact Louis Rossmann of Louis Rossmann group in NY New York. he may be able to repair it. https://www.rossmanngroup.com/
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 11
Insgesamt: 200
6 Kommentare
@danj do you have any idea?
von Ben Capehart
What broke? Post some pics so we can see Bilder zu einer vorhandenen Frage hinzufügen
Most of the time there is little you can do as the frame is well anchored. You would need to replace the frame which is not easy and the cost would be more than replacing the logic board. If the latches are damaged you can try wedging some plastic to hold the needed pressure on the SO-DIMM.
von Dan
@danj its not the frame or latches,
Its the slot, a picture wouldn't be very useful,
The problem is inside the slot
von Ben Capehart
@beanman56 - New frame then, I would just replace the logic board at this point MacBook Pro 13" Unibody (Mid 2010) 2.4 GHz Logic Board
von Dan
:| don't want it THAT much,
But thanks again @danj
von Ben Capehart
1 weiteren Kommentar anzeigen
