Zum Hauptinhalt wechseln
Die MacBook Familie entstand im Jahr 2006 und ersetzte das iBook als Consumer Laptop.
3787 Fragen Alle anzeigen
Frage geschlossen
No LED Light on Magsafe Adapter
I have a first generation MacBook (Core Duo) that was given to me by a friend. The MB works great except that the magsafe charger doesn't charge the battery. The MB recognizes the adapter but just says "Not Charging." I have a new battery and have tried my daughter's adapter and they work fine.
The LED light on my magsafe also doesn't light up at all. I thought the adapter might be faulty, but it seems to work on my daughter's MB. It also runs my MB when plugged into the wall; just does not charge the battery.
Could this be a problem with the MB's magsafe connector (the part inside the MB that connects to the logic board)? I'm just hoping it is not the logic board.
Thanks for any help you might be able to offer
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
just checking - is your daughter's Magsafe adapter a 60W version? or does she have a MacBook Air and it's corresponding 45W charger?
your MacBook needs the 60W (or higher) to charge the battery. if by chance you're trying to use the MacBook Air's 45W charger, it might run the MacBook but not have enough power to charge the battery.
if you're not using a MacBook Air charger, then ignore the above - it would be some other problem.
War diese Antwort hilfreich?
Bewertung 0
6 Kommentare:
Thanks for the comment.
No, both MBs are the 13" Core Duo models. They are basically equivalent with 1.83 GHz processors.
von
Can you see the SAITE numbers on the adapters?
von
Sorry, what exactly are the SAITE numbers? Are those the output wattage, etc. of the adapter?
von
At the end of the top line on the adapter. Also is there a Apple logo on the outside of the adapter?
von
This is not an Apple adapter. It is an off-brand replacement. The numbers are: Model No. 1184; INPUT: 100 - 240V - 1.5A; 50 - 60Hz; OUTPUT: 16.5V - 3.65A.
von
1 weiteren Kommentar anzeigen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 7,077
