Zum Hauptinhalt wechseln
Eine Laptopserie von HP. Erkennbar an der Modellnummer G42-XXX-XX, die Endungen variieren je nach Ausstattung und Verkäufer.
Hard disk refusing to start
The laptop doesn’t want to power on it says hard disk
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
It's doesn't open
von
Einen Kommentar hinzufügen
1 Antwort
This laptop is super old, so if you have the original hard drive the odds are it likely failed. Listen near the palmrest for a persistent "click", or even check to see if the drive shows as a bootable device - on these, you press ESC and select Boot Menu - if you do not see your hard drive, it died.
You can replace it with an SSD, but given the age of the laptop as a precaution look for a drive with SATA II/III support, on the off chance it is too old to use SATA III. This should be new enough, but some of the ultra budget HPs held onto SATA II speeds as a cost reducer for a little too long - this is one of those which might have that issue. Your best bet will be a Samsung SSD, as most other drives are now Fixed III.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Albert einstein wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 17
Insgesamt: 226
