Zum Hauptinhalt wechseln
Dell Inspiron 13-7373 Battery Replacement
Was du brauchst
  1. Dell Inspiron 13-7373 Battery Replacement, Back Cover: Schritt 1, Bild 1 von 3 Dell Inspiron 13-7373 Battery Replacement, Back Cover: Schritt 1, Bild 2 von 3 Dell Inspiron 13-7373 Battery Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Remove the ten 7.5mm Phillips #00 screws from the bottom of the laptop.
    • Use an opening tool to remove the bottom half of the case from the laptop.
  2. Dell Inspiron 13-7373 Battery Replacement, Battery: Schritt 2, Bild 1 von 1
    • Use a Phillips screwdriver to remove the four screws holding the battery in place.
  3. Dell Inspiron 13-7373 Battery Replacement: Schritt 3, Bild 1 von 2 Dell Inspiron 13-7373 Battery Replacement: Schritt 3, Bild 2 von 2
    • Pull the plastic tab on the battery cable to disconnect the cable from the battery.
  4. Dell Inspiron 13-7373 Battery Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 13-7373 Battery Replacement: Schritt 4, Bild 2 von 2
    • Remove the battery from the laptop.
Abschluss
For optimal performance, after completing this guide, calibrate your newly installed battery.
11 weitere Nutzer:innen haben diese Anleitung absolviert.
John Egan
449 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team S1-G4, O'Connell Fall 2019 Mitglied von UMass Dartmouth, Team S1-G4, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G4
3 Mitglieder
5 Anleitungen geschrieben
6 Kommentare
can you recommend a battery model #? I want to be certain I buy the correct one.
Peter Zinsli - Antwort
The first step needs to be amended. There are 10 back cover screws including the central one, not 9. Additionally, the battery cable removes outward from the battery, not upward.
Mike Vandenberg - Antwort
Hi Mike,
Thanks for the feedback! I’ll make the corrections you suggested.
Arthur Shi -
I'm told that you should replace the connector cable that connects the battery to the motherboard whenever you replace the battery. However that cable doesn't come with the kit. How do I get that part?
Bill Knapp - Antwort
I found that I had to remove the back of the laptop from the touchpad side of laptop first, not the hinge side first as indicated in the pictures.
Rich Hunt - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 34
Letzte 30 Tage: 146
Insgesamt: 15,746
