Zum Hauptinhalt wechseln
Lenovo ThinkPad T480s Fan Assembly Replacement
Was du brauchst
  1. Lenovo ThinkPad T480s Fan Assembly Replacement, Bottom Cover: Schritt 1, Bild 1 von 2 Lenovo ThinkPad T480s Fan Assembly Replacement, Bottom Cover: Schritt 1, Bild 2 von 2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s Fan Assembly Replacement: Schritt 2, Bild 1 von 3 Lenovo ThinkPad T480s Fan Assembly Replacement: Schritt 2, Bild 2 von 3 Lenovo ThinkPad T480s Fan Assembly Replacement: Schritt 2, Bild 3 von 3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s Fan Assembly Replacement: Schritt 3, Bild 1 von 2 Lenovo ThinkPad T480s Fan Assembly Replacement: Schritt 3, Bild 2 von 2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s Fan Assembly Replacement, Fan Assembly: Schritt 4, Bild 1 von 2 Lenovo ThinkPad T480s Fan Assembly Replacement, Fan Assembly: Schritt 4, Bild 2 von 2
    • Use the spudger to disconnect the fan cable from the motherboard.
  5. Lenovo ThinkPad T480s Fan Assembly Replacement: Schritt 5, Bild 1 von 2 Lenovo ThinkPad T480s Fan Assembly Replacement: Schritt 5, Bild 2 von 2
    • Loosen the six captive screws attaching the fan assembly to the motherboard.
    • This system was missing the two screws by the fan but I have highlighted them to show where they are located.
  6. Lenovo ThinkPad T480s Fan Assembly Replacement: Schritt 6, Bild 1 von 3 Lenovo ThinkPad T480s Fan Assembly Replacement: Schritt 6, Bild 2 von 3 Lenovo ThinkPad T480s Fan Assembly Replacement: Schritt 6, Bild 3 von 3
    • Lift the thermal fan assembly from the system and remove it.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Sarah Westberg
23.333 Reputation
70 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
136 Mitglieder
17.415 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 17
Letzte 30 Tage: 83
Insgesamt: 3,167
